Clean Pistons with Head Removed?
Old Apr 23, 2013 | 09:39 AM
nrraiders35's Avatar
Default Clean Pistons with Head Removed?
I have to do a head gasket repair on my 2001 4 cyl accord ex. I Notice carbon deposits on the top of the pistons while doing a piston soak in the hopes of slowing my oil consumption. Is there any way I can clean the carbon off the piston top and more importantly piston rings while I have the head off?
__________________
Old Apr 23, 2013 | 10:24 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Clean Pistons with Head Removed?
Carb cleaner? Seafoam? Gas + rag?
Old Apr 24, 2013 | 05:49 AM
MAD_MIKE's Avatar
MM Gruppe B
For the lazy man,such as myself, pour sea foam on top of the cylinders and let it sit, watch the carbon turn into goo.
For the more adventurous, gently scrape the carbon off the top off the piston using a utility knife blade, not a razor blade.
Old Apr 24, 2013 | 06:48 AM
92 civic ex 4dr's Avatar
What also works really well, is use good quality gas (shell Chevron 76 texaco) and drive it hard. Higher rpm's and internal heat breaks up the carbon deposits and keeps new deposits away.
My cd5 didn't have any carbon deposits on the head or pistons when i changed the head at 230,xxx miles.
Posted from Honda-tech.com App for Android
ryan_crx
Nov 9, 2007 07:41 AM
notguilty411
Jul 31, 2005 05:40 PM
b16 matt
Sep 26, 2004 05:15 PM
vtecmike1
Apr 28, 2004 08:36 PM
dubnine
Mar 26, 2004 10:22 AM
