98 Integra, B18b1 Engine. Car wont start!!
Looking for some help here.
My car wont start.
The starter is fine, alternator is fine, battery is new, main relay is good. Replaced the fuel pump Saturday and it started fine. After sitting overnight it wouldn't start. The fuel pump is getting power still though. Then changed the spark plug hole gaskets and the valve cover gasket. We were getting oil in our 1 and 2 spot spark plugs. We cleaned those out and put it all back together and it fired up first try. Started 3 more times that night (about an hour apart). Sat overnight, now will not start again.
The motor is trying to turn over, Makes its jump to turn over then fails. Same thing it was doing before all of the replacements.
My car wont start.
As mentioned, back to basics, new parts can be DOA, will not be the first time.
When the engine will not start, do you hear the fuel pump priming, each time you turn on the ign. to the run position?
Have you checked for spark when it will not start, use an HEI spark tester, and check each cylinder. 94
I get the car to turn over but not start. I hear the pump every time. Where do you suggest I get the HEI tester?
Thanks for the help everybody. Keep them coming. I will post more when I get chance after work.
You can pick up the HEI spark tester at any auto parts store, $10-$15...
http://www.oreillyauto.com/site/c/de...6.oap?pt=N0221 94
hamburgler
Aug 21, 2011 10:23 AM
szczerbanator
Jun 26, 2009 09:07 AM
