Parting out 93 GS-R
I forgot about the regulations and my thread apparently got deleted... Oops! Hopefully this one meets and will stay.
As the title states, I have decided to part out my 93 GS-R. Body has 296k on the odometer. Currently has a JDM B16 that has jumped time after missing on a drive home. compression checks as follows (180/180/180/200) Have the original B17 (#1 rod bearing is shot, have not torn it apart to find out if anything more wrong) Car has typical honda cancer on the rear quarters, some on drivers door and hatch.
To easier get a hold of me email me at: mzeglis@gmail.com
More part Images on Page 2
Red/Amber Tails
JDM Headlights (SOLD) and Clear Bumper Lights
JDM Headlights (SOLD) and Amber Bumper Lights
Interior and Arm Rest (ARM REST SOLD)
Valve Cover is quite this clean still but close (Had it powder coated in 08). (PLUG WIRE COVER SOLD)
If you want more photos of other items just ask me!!!
I DO NOT HAVE OEM FLOOR MATS (SORRY)
Some basics of upgraded parts are as follows:
JDM 1-piece headlights (no cracks or chips, not crystal clear, but in good shape) SOLD
K&N stock filter
Skunk2 weighted shift ****
90-00 civic short shifter (SOLD)
JDM amber side markers
Amber bumper turn signals
also have all clear bumper turn signals
Ground Control Coil Overs (tokiko HP Blues passanger rear is blown)(these coilovers will only fit the following shocks: Stock/OEM, Sachs, Tokico HP ('Blues'), Tokico Illumina ('Whites')) (SOLD)
Trans was disassembled with honda mechanic and carbon coated syncros installed (SOLD)
Hi-Flow Cat
OEM Acura sunroof visor (has hairline crack but doesn't affect it at all)
DOHC Fender Moldings
Exeddy Stage 1 racing clutch and pressure plate (SOLD)
ACT 11.5 lbs flywheel (both clutch and flywheel have about 40k on them but had no problem spinning 2nd and chirping 3rd with them) (SOLD)
Good stock parts:
Virgin stock ECU
Front and Rear Stock Mud Flaps (REARS SOLD)
Red/Amber tails in mint condition
Gray/Blue interior mint except Driver seat has tear on side bolster.
Arm Rest with cup holders (SOLD)
A/C-Heat controls
Interior switches
stock cat-back exhaust replaced a little over a year ago
Alternator
starter
PS pump
reservoirs
VTEC side moldings
Many other parts are still good.
I also have the full Factory Service Manuals (two books about 1-1/2" thick each that cover everything down basically to the size of every bolt)
I also have a set of SI rims. some have oxidation on them. started to sand down one of them. Tires are shot.
$250
Much rather not ship these if possible.
If someone wants to buy it all outright Awsome, but I'll take reasonable offers on all parts.
If you need something and don't see it, just ask.
FOLLOWING ITEMS ARE SOLD:
JDM 1-PIECE HEAD LIGHTS
CLUSTER
ENGINE HARNESS
BODY HARNESS
RADIATOR AND FANS
INTERIOR PANEL UNDER STEERING COLUMN WITH COIN TRAY
POWER STEERING PUMP BRACKETS
SPARK PLUG COVER
ARMREST
REAR MUD FLAPS
SHORT SHIFTER
OEM INTAKE BOX AND TUBE (K&N FILTER STILL AVAILABLE)
GROUND CONTROL COIL OVERS
DRIVER'S DOOR WINDOW SWITCH
DOOR SIDE MOLDINGS
TRANSMISSION
MOTOR MOUNTS
CLUTCH / FLYWHEEL
All other items are still for sale ask for price and shipping cost.
Red/Amber Tails
K&N stock filter
Hi-Flow Cat
Good stock parts:
Virgin stock ECU
A/C-Heat controls
Interior switches
Alternator
starter
PS pump
reservoirs
VTEC side moldings
$250
CLUSTER
ENGINE HARNESS
BODY HARNESS
RADIATOR AND FANS
SPARK PLUG COVER
ARMREST
REAR MUD FLAPS
SHORT SHIFTER
DOOR SIDE MOLDINGS
TRANSMISSION
MOTOR MOUNTS
CLUTCH / FLYWHEEL
Last edited by ziggy7; Jun 25, 2013 at 12:23 PM. Reason: PARTS / SOLD PARTS LISTS UPDATED
I'm north of Chicago so shipping would be best
Note that a new throw-out bearing was installed when the carbon syncros were put in and there is also a xeddy stage 1 clutch and pressure plate, with an ACT 11.5 lbs flywheel.
Ok, so I have so many PM's coming in that I'm gonna do this as follows: for the people that have already contacted me about parts, you have 24 hours to confirm or make payment on parts or I will consider them unsold and it will become first person to send or show up with $ takes the part.
Sold Parts List
JDM 1-Pieces - SOLD
Guage Clister - SOLD
Armrest - SOLD
Distributor - SOLD
Engine Wire Harness - SOLD
Body Wire Harnes - SOLD
Radiator and Fans - SOLD
Interior Panel Below Steering Column - SOLD
Still plenty more, make me offers.
JDM 1-Pieces - SOLD
Armrest - SOLD
Distributor - SOLD
