h22 fitment issues into 90 cb7
Old Apr 22, 2013 | 11:18 AM
jimmy o.'s Avatar
Default h22 fitment issues into 90 cb7
I can't get any of the mounts in this car lined up except the rear and the trans mount I've already moved the studs from the trans to I need to move the mount bracket on the driver side from the f22 and put it kn the h22 tgey look the same but I'm stooped ive done several swaps before civics integra prelude but never one this difficult ive messed with it for hours it just doesn't seem like its gonna work at all any ideas?
Old Apr 22, 2013 | 11:27 AM
sleepyaccord96's Avatar
Default Re: h22 fitment issues into 90 cb7
use a 92 96 prelude drivers side mount (near timing cover) and grind on it a bit and it'll fit right in!
Old Apr 22, 2013 | 11:34 AM
jimmy o.'s Avatar
I have the one that came with the swap its a 92-95 spec motor and where would I grind on it?
On rear of it
Old Apr 22, 2013 | 12:40 PM
jimmy o.'s Avatar
Nvm I got it in thanks
Old Apr 22, 2013 | 01:17 PM
what did you do? did u see how the prelude mount is a tad bit too wide to fit into the drivers side motor mount "pocket" ?
Old Apr 22, 2013 | 04:19 PM
holmesnmanny's Avatar
you need to remove the front-to-back support member under the engine...use all your accord mounts and brackets..they work fine...also take off the crank pulley so you don't bang it up against the driver side chassis...it will give you more room
Old Apr 22, 2013 | 05:14 PM
jimmy o.'s Avatar
Yeah I got it in the driver mount was a little tight so i grinded it down some also for some reason the ac bracket was hitting so I pulled that off when in real easy after that thanks
Old Apr 22, 2013 | 08:30 PM
You don't grind down any mounts for your car at all. If you did, the mount is not going to last for as long.
Old Apr 23, 2013 | 07:19 AM
jimmy o.'s Avatar
The mount bracket attached to the block not the Mount itself
Laskowski
Mar 11, 2011 03:10 PM
jfish
Oct 9, 2005 07:59 AM
Luserkid
Dec 9, 2004 10:07 PM
OutlawCL
Oct 2, 2004 11:32 PM
OutlawCL
Sep 11, 2004 01:20 PM
