ECU for B16A obd2?
Old Apr 22, 2013 | 08:06 AM
PaPo's Avatar
Default ECU for B16A obd2?
i bought a B16A obd2 swap for my teg build, he gave me a p72. is that the right ecu or do i need to get a different kind?? which one will work best for the swap? im a noob
Old Apr 22, 2013 | 08:59 AM
3rdtimecharmer's Avatar
10 Year Member
Default Re: ECU for B16A obd2?
yes,
i think p28 is best? idk. i have a f2b so gyea.
but 1.6 in a integra?
what year is your integra. is it OBD1 or OBD2?
get your money back and buy a GSR swap.
Old Apr 22, 2013 | 09:37 AM
PaPo's Avatar
lol thats what everyones been telling me. i mean 168hp is just as good as a gsr. its cause i got it for a good *** deal. but if i dont like the results ill change it.
its an obd2
Old Apr 22, 2013 | 10:05 AM
B_Swapped93's Avatar
its an obd2
but you'r 111lbs of TQ is not as good as the 128 in a gsr....
Old Apr 22, 2013 | 11:28 AM
10 Year Member
+1
Old Apr 22, 2013 | 12:55 PM
jdmjackson's Avatar
Originally Posted by 3rdtimecharmer
+1
i would convert to obd1 and run a p30. b16 should be fine in the dc with the shorter geared b16 trans should make up for tq loss
Old Apr 22, 2013 | 12:59 PM
10 Year Member
no replacement for displacement.
Old Apr 22, 2013 | 01:00 PM
It still feels like a D down low...and shorter gears are not fun on the highway.... it's a TQless engine and no fun imo.
Old Apr 22, 2013 | 01:41 PM
kchungb17a's Avatar
VTEC activation will be too low with a P72. If you want to stay OBD2 you can use an EM1 SI ECU. Otherwise do the OBD1 conversion and use the P30 as suggested, but those ECU's are hard to come by. But then again, EM1 SI ECU's probably are too.
Old Apr 22, 2013 | 02:43 PM
HondaPartsHero's Avatar
Technical Hero
What year is your Integra?
96-97 P30 will plug and play in a 96-99 Integra
99-00 P2T will plug and play in an 00-01 Integra
You can use either with ECU adapters depending on your year.
Old Apr 23, 2013 | 08:08 AM
PaPo's Avatar
or how about this. i had a dream and came up with a brilliant idea. How about i take motor apart. sell the long block, keep the tranny and head. buy an ls block. put them together and rape a couple hondas?? plus ill have extra money in pocket
Old Apr 23, 2013 | 08:14 AM
kyden's Avatar
you mean sell the shortblock? a longblock is a complete engine.
how cheap is this swap?
Old Apr 23, 2013 | 08:46 AM
PaPo's Avatar
oops, cant believe i didnt catch that. $700
S4gasm
Oct 30, 2004 12:05 PM
fatalman
Dec 22, 2003 06:50 PM
SilverEk3dr
Dec 24, 2002 07:48 PM
