rad cap on 93 del sol si?
Old Apr 21, 2013 | 07:59 PM
93 del sol si2's Avatar
Default rad cap on 93 del sol si?
hi guys, I am going to change my rad cap but I don't know whats best OEM? What brand do you guys use? My car is high mileage, all stock.
Can a bad rad cap cause the overflow level to increase and fill up? My car started overheating and I checked the rad overflow, it was past full, the rad itself was a bit low. I dumped the overflow to between low and full, filled the rad, car was fine.
p.s.- yes, I'm burning coolant too. I'm still trying to save up for engine work (HG), but I know the rad cap COULD cause this issue as well.....
Old Apr 21, 2013 | 08:11 PM
B_Swapped93's Avatar
Default Re: rad cap on 93 del sol si?
OEM. Anything else for a stock car is useless/overkill.
Old Apr 21, 2013 | 08:47 PM
OEM though is what, 25 bucks at Honda? I'm thinking just going to PartSource or Canadian Tire? (I'm in Ontario)
Old Apr 22, 2013 | 10:20 PM
bump
Old Apr 22, 2013 | 11:02 PM
Lil Gnome's Avatar
Dude, check the brand of your radiator. Go to which ever parts store you'd like. Buy the cap. Go home. As long as it can hold pressure, 15p.s.i., it'll do the job as a cap.
Vagitarian
May 25, 2012 02:46 PM
trevek10
May 15, 2011 10:26 AM
sorullo
Jun 18, 2008 03:37 PM
bleedblue94
Aug 18, 2007 08:37 AM
matt56
13
Aug 17, 2006 07:32 PM
