HELP ! GSR motor problems
Old Apr 21, 2013 | 06:35 PM
Mikes95eg's Avatar
Default HELP ! GSR motor problems
It's beginning to frustrate me ...
The car was sitting for about a month...
Did a fresh oil change, let it run for a little the same day till battery died.
(Had a horrible battery so it would only run like 30mins)
Then today about, 2-3 weeks after oil change I bought a NEW battery.
MIND YOU THIS HAS NEVER HAPPENED BEFORE..
I turn it on, and the whole motor was shaking for like 5mins+
I took it for a drive , when I would turn the motor would being to shake and it was really really hard to turn WTF?
THEN! to top it all off, I would hit the gas and the car wouldn't want to go any where and it would be all bouncy and **** ! IDK
WHATS GOING ON ?! HELP PLEASE..
WHAT COULD IT BE ???
Old Apr 21, 2013 | 06:45 PM
Blackhalo6's Avatar
Default Re: HELP ! GSR motor problems
Car dying on electrical power while running is indicative of a bad alternator, outside of that, the symptoms your describing could be anything. Any codes or any other symptoms?
Old Apr 21, 2013 | 06:47 PM
S2BumpsticksGSR's Avatar
First of all, your eng runs off the alt, not the batt. The batt is mostly for starting. Check your alt output. I've driven a few cars after being jumpstarted w/o a battery even in the car 50+mile trips mind you.
Old Apr 21, 2013 | 07:00 PM
B_Swapped93's Avatar
how new is you'r cap and rotor ? getting any codes ?
Old Apr 21, 2013 | 07:26 PM
el crapitan's Avatar
as mentioned, have a thorough charging system test performed.
if it's not the charging system, i'm wondering if maybe you have a seized pulley, dragging the motor down. since you say it was very hard to turn/no power/engine almost dies.
or maybe the power steering fluid is just low..
hatch92_88crx
Feb 15, 2006 08:22 PM
hatch92_88crx
Feb 15, 2006 06:59 PM
DJ Gurgla GSR
Dec 19, 2005 04:27 PM
90AcuraIntegra04
Nov 1, 2005 07:19 PM
YAY!
Mar 2, 2004 06:50 PM
