95 Civic Engine Code 9
Old Apr 21, 2013 | 03:07 PM
Bustin_Hatch305's Avatar
Default 95 Civic Engine Code 9
I have a eg hatch with a mini me d15b7/z6 and its throwing code 9
CYP - Cylinder position sensor
i have a brand new vtec distributor so i dont know why its throwing this code.
Also when ever i give it gas you can hear a knocking noise coming from the head or distributor i cant really tell but when your driving it goes away.
Any suggestions?
Old Apr 21, 2013 | 04:40 PM
Default Re: 95 Civic Engine Code 9
up
Old Apr 21, 2013 | 04:44 PM
HondaPartsHero's Avatar
Technical Hero
Test the sensor
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/95-civic-limp-mode-tps-ckp-cel-codes-please-help-3040811/
Old May 26, 2013 | 08:25 PM
BlueVic_8354's Avatar
Any suggestions?
Good day... have you fixed this problem? i have the similar problem.
I have been reading a lot of information and posts on the net regarding this Code 9 CYP error on my engine. But everything is not working. My engine is a JDM ZC SOHC VTEC on rechipped PO8 ECU. Here is the case:
Early this year, i had my cylinder head gasket replaced, since the head is already out, we shaved off about two thousandth of a millimeter from the head. the build was going fine until after about a month, my engine started to throw code 9. thinking it was the distributor, i had it changed. but still code 9 was on. checked the wiring based on the Honda service manual, all seems to be good. just to get the code 9 out, i did the following: cleaned the TB and IACV, adjusted the TPS, changed the fuel pump, main fuel relay, spark plug wires, spark plugs, fuel filter, distributor rotor, re-checked all over again the wiring, replaced the chip 3 times, advanced and retarded the timing, and advanced and retarded the cam gear fro +4 all the way to -2, . i also tested my ECU with another car. the ECU works just fine, and no CEL at all. but as i use my ECU back on my car, CEL code 9 will turn on, then it will be hard to start, not to mention rough idle, as if the engine is misfiring.
i hope you guys could help me, i cannot afford another engine swap. my friends say that my engine is quite creepy and weird.
tygerEF2
Jul 12, 2011 03:27 PM
nabin
Jun 13, 2007 11:24 PM
polymath
Mar 29, 2005 04:31 AM
Forrest Gump 9
May 14, 2004 04:59 AM
GuyInASpeedo
Sep 25, 2003 07:05 PM
