Intake or Exhaust
Old Apr 21, 2013 | 02:19 PM
dseriessquad's Avatar
Default Intake or Exhaust
I have a 2000 civic ex with the following engine mods
cat back
high flow cat
255 fuel pump
short ram
crower stage one cam and adjustable gear
i need to decide whether to do an aftermarket intake manifold or aftermarket header. which would give more gains? i know that both together would but right now i only have the funds for one of the two.
Old Apr 21, 2013 | 02:27 PM
jbpnoman's Avatar
Default Re: Intake or Exhaust
If you're buying no-name, off eBay parts, then neither. If you're buying quality, branded parts, either. It really doesn't matter, but I'm also guessing you don't have $500 for a quality, branded part.
Old Apr 21, 2013 | 03:52 PM
my budget is like 300-350. i just want the part with the most potential gains
Old Apr 21, 2013 | 03:57 PM
B_Swapped93's Avatar
What's with the 255LPH pump ? unless it came like that: overkill
you won't get a quality exhaust for 300 save or get the ITM.
Old Apr 21, 2013 | 03:59 PM
grumblemarc's Avatar
The Grumpiest
Pick one. The only way you'll know is on a dyno.
Old Apr 21, 2013 | 04:06 PM
yeah i bought it with a walbro 255 fuel pump. no idea why the guy put it in but its there.
Old Apr 21, 2013 | 04:07 PM
The Grumpiest
If there's no tune or basemap for it, all those mods are just a waste. After a while if you keep slapping on power adders your performance will actually start to get worse.
Old Apr 21, 2013 | 07:13 PM
if i did decide to do a tune it wouldnt be for a while. i wanted to get the intake or exhaust decided before i started messing with the ecu
Old Apr 21, 2013 | 07:26 PM
xile6's Avatar
Good intake and cheap header and you can get both.
But I like to get exhaust done first before you start trying to cram more air into the cylinders.
Old Apr 21, 2013 | 09:03 PM
eghatch9295's Avatar
Stancetard Hate Monger
wouldnt really bother with either. id source the web for a used manifold, if anything,
Old Apr 21, 2013 | 09:05 PM
jbpnoman's Avatar
He's talking about an intake manifold, not intake piping. A "good" (and I use that word lightly) cheap IM is going to run $400 minimum, and that's not counting the machine work necessary to port match.
Old Apr 21, 2013 | 09:10 PM
misterEJ's Avatar
i'd look into getting a new camshaft. it should give you more power throughout the whole rpm range especially if it's tuned right. aftermarket mods for the intake/exhaust won't help as much but they're around the same price **nevermind just realized i missed that on your first post. well i'd go with the intake but i'm assuming they'll be about the same
Old Apr 21, 2013 | 09:27 PM
jbpnoman's Avatar
A cam worth two ***** would require a tune when it was installed. He also already has one.
Actually, now that I think about it, OP, you should consider spending that money on a socketed P28, wideband, Moates Ostrich, and a lot of time reading and learning, and learn how to tune your car yourself. You'd gain more power from that than you ever could from a manifold.
Old Apr 21, 2013 | 09:37 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
So your running a aftermarket cam with a stock ecu??? I would start with that ecu. Anything else's would be a waste at this point!
Old Apr 21, 2013 | 11:40 PM
staciwaas's Avatar
Old Apr 21, 2013 | 11:49 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
you need the intake exhaust cam header and a tune to take advantage of everything, if part of the airflow path is blocked, everything else becomes worthless. air can only flow as fast as the most restrictive point
Old Apr 22, 2013 | 03:42 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Save your money and go turbo.
Old Apr 22, 2013 | 05:59 AM
xile6's Avatar
ive seen manifolds go for around $250-$300 and cheap ebay headers for $50.
either way I skip all that and went turbo.
but more power is gain with a tune .
Old Apr 22, 2013 | 12:00 PM
i found a used edlebrock manifold for 280. i think im going with that. its a stage one cam so the valve train isnt upgraged and i think i can run it for now without a tune. id go turbo but for a d series id be better off swapping engines
Old Apr 22, 2013 | 12:39 PM
You need a tune when upgrading anything internally like cams.
Your just wasting money trying to put bolt ons on a d series. Boost it or b swap.
Old Apr 22, 2013 | 01:39 PM
doctorake's Avatar
Community Builder
You have not listened to a word of advice in this entire thread have you.
Old Apr 22, 2013 | 01:45 PM
he's not listening, to the OP, with a cam the valve train geometry is changed, the ecu has to be programed for that change. A cam is not a bolt on. even a stage one is a big change, you need to tune for it
Old Apr 22, 2013 | 06:41 PM
so ill need to learn how to tune over the summer. got it
Old Apr 22, 2013 | 08:03 PM
i should mention that everything except the cam was already done when i bought the car so i havent been dumping money into it. adding a cam and intake manifold for under 500 is cheaper than any swap or turbo build
Old Apr 22, 2013 | 08:48 PM
But horsepower to dollar ratio, turbo is cheaper!!! D's were never meant for performance, they are the epitome of economy motors and that's why bolt ons do very little in the power dept.
