Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2006 SI No start
Old Apr 21, 2013 | 11:13 AM
bigboy56's Avatar
Default 2006 SI No start
Pulling our hair out. No Spark or fuel pump. changed ECU with matching key
both fuse blocks, insterment panel. Checking wiring harness. No battery volts
a f/ecat relay but have key on volts. Has anyone seen bad fuse blocks? Going to change wiring harness next but something doesn't make sense
Old Apr 28, 2013 | 08:40 PM
BurntBisquit763's Avatar
Default Re: 2006 SI No start
I would double check everything before you start throwing more money at it, check connectors, grounds and everything you touched during the process
davidayala831
Dec 1, 2017 12:15 PM
smbignick
Aug 18, 2013 01:47 PM
LiftNRace
Jun 1, 2013 01:22 PM
DIYZane
Jan 15, 2008 11:27 AM
