GSR crank stuck
Old Apr 20, 2013 | 07:04 PM
gp356's Avatar
Icon3 GSR crank stuck
Engine shutoff while rolling to a stop, car started briefly and was idling rough before shutting off. after that the car would not crank over.
removed the starter and head and the crank will still not sping by hand.
the wheels spin freely even when trans is in gear, but the crank doesnt.
someone please help idk where to begin.
Old Apr 20, 2013 | 07:34 PM
B_Swapped93's Avatar
Default Re: GSR crank stuck
are you sure ? attach a 19mm socket to the crank bolt and try turning it.
Old Apr 20, 2013 | 10:20 PM
gp356's Avatar
I did. That ****** is stuck. Coincidentally, thats why I said the crank was seized. Not to sound like a dick
Old Apr 21, 2013 | 12:28 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Has the car overheated ??? Did you hear any noises before the engine quit and would not start again ???
Have you checked the mechanical timing to make sure your cam/crank phasing is not out of whack ??? Severe valve to piston or valve to valve contact will stop an engine from spinning.
Old Apr 21, 2013 | 04:43 AM
gp356's Avatar
I was not aware of the engine overheating if it did and didnt seem so. and no significant noises before it died.
the head is off as i stated so regardless the block still doesnt spin
the head was inspected and looks fine
timing was fine
Old Apr 21, 2013 | 04:51 AM
grumblemarc's Avatar
The Grumpiest
If the crank is indeed seized then what's the question? Start a teardown and start inspecting or buy another engine. At the very least drop the oil pan!!!
Old Apr 21, 2013 | 04:56 AM
Discosteak's Avatar
if the wheels spin freely in gear the clutch may have come apart and a piece is holding the flywheel
Old Apr 21, 2013 | 05:00 AM
The Grumpiest
Ew. Looks like somethings coming apart either way.
Old Apr 21, 2013 | 06:14 AM
gp356's Avatar
yea doesnt look so good. there was some shavings in the oil pick up filter but theres no play in any of the bearings. assuming one of those spun would that be able to sieze the entire crank? it didnt have a knock it justs suddenly shut off. ill post a video of when it ran for the short period of time.
Old Apr 21, 2013 | 08:00 AM
Discosteak's Avatar
its possible for the crank to seize without making noise although it is uncommon. Like i said though if the wheels spin freely in gear without turning the crank it is highly possible that the clutch fell apart and something is holding the flywheel from turning.
Old Apr 22, 2013 | 09:41 AM
gp356's Avatar
unfortunatly that was not the issue... one of the rod bearing halves spun over the other and was so jammed in there that it wouldnt allow the rod to rotate around the crank. once i loosened the rod cap the crank came loose
Old Apr 22, 2013 | 05:45 PM
Discosteak's Avatar
look on the bright side it wasnt a main bearing.....
Old Apr 23, 2013 | 06:23 AM
kyden's Avatar
there must have surely been a sign that the bearing was going to spin.
Hondacamaro
Mar 20, 2015 10:21 AM
nemesis.442
17
May 7, 2012 12:34 PM
fastdohc
Jul 23, 2010 07:22 PM
88crxdxfastwhip
Mar 18, 2007 05:16 AM
jackstands
Mar 13, 2005 08:54 AM
