DA-NINE's Poor man's R build
Old Apr 20, 2013 | 08:28 AM
DA-NINE's Avatar
Default DA-NINE's Poor man's R build
Hey guys, I finally got something together worth posting
I just graduated school and started working at a Honda dealership so money is finally flowing, slowly but surely.
I have a 92' integra thats 2625lbs with me in it full interior etc etc.
Engine:
b18c1 block stock sleeves 81.5mm
B18a/b Crank
b18a/b Rods
Pr3 pistons
Hastings rings
B17a pr3 head
stock valvetrain
Arp Head studs
Arp Rod bolts
OEM head gasket
ACL Race bearings
Skunk2 Pro Series Black intake manifold
Skunk 2 alpha 70mm throttle body
Skunk2 alpha header
Msd Pro Billet distributor and coil
Neptune Rtp
AEM UEGO wideband.
trying to decide on a cam!
Looking at skunk2, kelford etc
Is there any cam comparison threads?
Pics coming soon
Old Apr 20, 2013 | 10:33 AM
98vtec's Avatar
moderator emeritus
Default Re: DA-NINE's Poor man's R build
Read the faq
Old Apr 25, 2013 | 11:58 AM
DA-NINE's Avatar
Read Through the faq and has pointed me towards a sets of Tuner2's or Pro1's.
From what I read the Pro 1s might be a bit much for my setup.
Has anyone experienced a skunk2 70mm throttle body whistling at part throttle?
Old Apr 27, 2013 | 04:11 AM
newfie_boy's Avatar
I like tuner 2's
Old Apr 27, 2013 | 01:58 PM
TheShodan's Avatar
Moderator
Pro1s are fine for that setup. Just fine.
Old Apr 28, 2013 | 03:53 AM
DA-NINE's Avatar
Thanks for the info Shodan.
Hey side note Shodan, Efficiency band on the Silver Surfer? I have one on my 1.9l b16 crx on 16lbs of gate spring. do you have a compressor map or anything you could send me. I have proof of purchase.
Has anyone tried the N/a Power division cams? N2's i think.
Old Apr 28, 2013 | 07:21 AM
TheShodan's Avatar
Moderator
N1 GSC cams are similar to the Edlebrock 4730s with a bit more punch.
That question should be on the FI forum, or just give me a PM. As for a map, that's not available to the public, unfortunately.
Old May 1, 2013 | 11:56 AM
Colin's Avatar
I don't have the Skunk2 TB, but my car too makes a whistling. It doesn't do it while cruising, only during acceleration. I Never figured out what the reason for it was, but I've been thinking it's the plastic TB gasket since, with the exception of my intake, everything else is OEM. Seeing that you are having whistling and are also running a plastic TB gasket is another sign that the gasket might be the issue, but who knows.
Old May 2, 2013 | 09:13 AM
JuggerNaut-CTR's Avatar
x2 on the pro1's
Whats going on with that engine bay dude? Needs a lil love
Baddawg1991
17
Nov 4, 2014 06:59 PM
R3Ycivic
40
Jan 15, 2013 02:01 PM
01oemTeggy
80
Sep 30, 2012 09:36 AM
rsa0905
Oct 14, 2010 12:48 PM
STHPERFORMANCE
20
Nov 1, 2003 07:09 AM
