Non vtec head (d15Z4) on vtec block ( d15Z8 )
Old Apr 20, 2013 | 03:52 AM
redrix's Avatar
Default Non vtec head (d15Z4) on vtec block ( d15Z8 )
Hi everybody,
I'm here to ask you if i can put a non vtec head from d15Z4 on vtec block d15Z8 ?
Because now the d15Z8 was swapped into an EK3 civic wich has a D15Z4 after it blown. And the d15Z8 is running with the Z4 ECU and the vtec is not working. Thats why i want to put a non vtec d15Z4 head on the d15Z8 vtec block.
Do you think it'll work better than now with non workin' vtec ?
Thanks all.
Old Apr 20, 2013 | 09:27 AM
redrix's Avatar
Default Re: Non vtec head (d15Z4) on vtec block ( d15Z8 )
up
Old Apr 20, 2013 | 09:30 AM
B_Swapped93's Avatar
Don't know if it'll wotk better as you haven't said what it's doing wrong. But it will work you'll just have the lose vtec plugs.
Old Apr 20, 2013 | 09:34 AM
redrix's Avatar
The d15Z8 is a Vtec-Eco, so 12v at 4000rpm then 16v after 5xxxrpm ( it's too slow comparing with the same civic with z4 engine non vtec )
actually the vtec is not connected ( z4 ecu ) and i can't get Z8 ecu and harness to convert it. That's why i want to swap the head.
the goad is to get the same performence as the d15Z4 engine.
What do you think ?
Old Apr 21, 2013 | 01:06 AM
redrix's Avatar
up
Mauro Gelbert
Mar 3, 2016 02:03 PM
erik_cd5
Sep 18, 2011 12:14 PM
BoltSOCpower
Oct 24, 2010 03:06 PM
jivi
Honda Civic (2001 - 2005)
Apr 19, 2007 06:28 PM
big bentley
Apr 11, 2002 07:21 AM
