Annoying 1995 civic lx probelm
Old Apr 19, 2013 | 02:21 PM
NickElder's Avatar
Default Annoying 1995 civic lx probelm
When it rains my fuel pump doesn't prime, and my CEL comes on and stays solid. When it is dry the fuel pump primes and engine starts fine. Here is what I have done so far:
Checked all fuses (went ahead and changed fuses 12, 18, and 24 under dash, and 31 under hood.)
Changed relay to pump.
Changed fuel pump.
With the Key in the on position I get a reading from pins 2 and 6 going to the main relay.
I am thinking maybe its the ecu, is there anything else I should check before I changed it? Also I was wondering if i can put a p06 ecu in it? It has a p26
Old Apr 19, 2013 | 02:31 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Annoying 1995 civic lx probelm
Seems obvious to me that you should be looking for moisture in those areas.
Bushybob94
Jun 5, 2018 11:40 AM
Whiteonblackej
82
Mar 19, 2015 12:55 PM
madmax94
Feb 28, 2011 02:03 AM
krysted9354
20
Apr 8, 2009 03:32 PM
bc matt
Apr 2, 2005 01:17 PM
