Cooling system question(s).
Was just wondering my t-stat got stuck closed several times lately so i ditched it and am currently running with out. But before open loop is mentioned my ECU runs constant open loop thus running off the chips fuel maps gas millage is fine tho(no primary o2 even). So other than that any reason not to get one asap i'll get a new one sooner or later but till then.
2nd my rad fan doessn't come on, jumped the fan switch plug comes on...do i replace the switch in the case(thing on the t-stat housing). thanks
The 2nd fan only comes on when the AC is on, so unless you run the AC, it won't come on.
Overcooling is the main issue with running with no tstat.
Over cooling is not a good thing. Go buy a new t stat and install it asap.
Have no AC so that's how it's supposed to function(not come on at all ?). will grab new t-stat when in town then I guess.
Strange, in my 95, they both fire up simultaneously w/o a/c on. And, no, they're not rigged. They're plugged straight into the factory relays.
Op- I would test the fan relay before testing the switch by t-stat. Or you can ghetto wire your fans to acc key position by bypassing the relay with a jumper wire.
got a stat will put it in tomorrow. yes i did notice the car was virtualy in the "cold" on the gauge during my whole trip to/from town 15 minute drive both ways. will replace fan switch at sum piont to but it never really gets hotter then +27C so like +80F in the summer here lol.
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
if they still wire them like they used to, it has a module that only lets the second fan come on after a certain temp,
Replaced t stat as the car fell flat on it's face when i tired to start it tonight lol guess you DO need it. will get around to the fan switch to. do the 96-00 civic ones fit ?
with the t stat out, the fan won't come on. ever.
with the t stat in now, get it hot. see if the fan comes on now.
also, just so you know, ECT still plays a huge role in fuel delivery. regardless of being in open loop or not
have yet to bleed the coolant sys fully properly just squshed the hoses a few times. temp gauge sits under half bu a bit is that normal
Replace the fan switch, make sure you burp it properly, and replace your rotor and cap. Try not driving it so much, because your rotor and cap are completely shot. I've never actually seen one wear out that badly in person (I always replace them at the first sign of ANY wearing out, which is usually more often than most people would replace them)
I have no AC and if i push the ac button(not that it's connected to anything) still nothing happens engine was warm(gauge read a bit under half) can you tell me where the relay is i had trouble finding a diagram.
In front of radiator(I know a stupid place) on drivers side hanging off top of core support. I know you don't have a/c. I was trying to say that both of mine turn on @ same time w/o(without) a/c on. I've never had just 1 activate on my 95.
alright found it and what am i looking for with the relay ? shorted/burnt something like that ?. im horrible with electrics my appoligies
this guy
ls1formula98
Apr 14, 2015 06:05 PM
FOrSfEd
Jul 14, 2004 05:08 PM
