98 Accord Cp V6 fuel tank pressure sensor
I found it, it's on the drivers (Left) side of car, behind L rear wheel next (forward of) to gas tank.
1. Drop emergency brake cable (2 12mm bolts)
2. Drop front 2 of 3 (10mm bolts) of Evap canister assembly
3. Remove plastic cover (3 plastic push tabs) around pressure sensor
4. Also makes it easer if you drop (1 10mm bolt) the round thing next to assembly.
Mypacklouder
Nov 16, 2018 04:32 PM
sony224422
Feb 16, 2018 10:12 AM
