rattling/vibrating by pulleys
Old Apr 18, 2013 | 07:42 PM
tecatown2091's Avatar
Default rattling/vibrating by pulleys
alright just got back from a 8 hour drive and when i coming home i notice a rattling noise by the pulleys .almost sounds like a exhaust leak but i think its something else.it happens when parked and i give it gas and moving giving it gas .but it has to be a high rpm any ideas
Old Apr 18, 2013 | 07:59 PM
Default Re: rattling/vibrating by pulleys
also the bigger hose from the radiator that goes to a bottom pulley i can feel it vibrating or rattling in it
Old Apr 18, 2013 | 08:09 PM
hunan beef's Avatar
Lets start by you telling us what car you have, engine, ect....
Old Apr 18, 2013 | 08:14 PM
1997 civic hx d16y7 swap,stock.
Old Apr 18, 2013 | 09:05 PM
ej7attack's Avatar
start of by inspecting everything of the suspected area,making sure all pulleys are tight, belts, axles. check anything you can that spins for play. its happening in my car and seems pretty common is the input shaft bearings in the transmission going bad. hopefully thats not your case.
Old Apr 18, 2013 | 09:11 PM
ej7attack's Avatar
the radiator hoses go from the radiator to the head and thermostat. are you thinking a/c condensor? is there a/c in your car? perhaps the a/c clutch bearings are worn. check the a/c pulley for play. i know mine came with a/c.
Old Apr 19, 2013 | 05:20 AM
hunan beef's Avatar
X2, as well as what ej7attack mentioned. Try disconnecting that A/C belt (assuming you have A/C). If the car is manual, does the noise go away when the clutch is depressed?
jamesmoua
Honda Civic (2001 - 2005)
Aug 7, 2017 05:13 AM
Lil Gnome
11
May 3, 2013 10:51 AM
Lcurle
Nov 6, 2012 10:52 AM
wizeguy1
10
May 25, 2007 06:56 AM
Integra_RS
Apr 10, 2005 08:49 AM
