16x7 retracks 225/50/16
Old Apr 18, 2013 | 09:29 AM
xJDMB16x's Avatar
Default 16x7 retracks 225/50/16
I have a 97 ek hatch with16x7 retracks I'm trying to fit 225/50/16 I'm looking for a wide tire look I guess you could say some what of a auto cross look. Would I be ok with this size or is this just something to big that won't work... The only problem is I already bought the tires. If anyone has any input or info pics I would really appreciate it... I've seen cars with this kind of stance but I wasn't sure if I went to big I need help
Old Apr 18, 2013 | 10:38 AM
TIMMY4TOES's Avatar
Default Re: 16x7 retracks 225/50/16
They should fit some what easily. You just wont be able to lower it very much
Old Apr 18, 2013 | 10:48 AM
TIMMY4TOES's Avatar
sorry forgot to add, you might run into clearance turning with your front wheels. you should have ran a 40 series
Old Apr 18, 2013 | 10:52 AM
speedooo's Avatar
I had 16x7 w/ 225/50 on my ep3 and the tires were a little big. Good luck with that on the ek chassis.
Old Apr 18, 2013 | 08:16 PM
xJDMB16x's Avatar
I just wonder what its going to look like
Old Apr 19, 2013 | 12:47 AM
jbpnoman's Avatar
First off, you don't have an EK. Let's just get that out of the way now. You have an EJ6.
It's going to look 4x4 status. Those tires are WAY too big. Do you even understand how upsizing tires works? 205/45R16 would be the correct plus size, but if you want to go 225, it would be 225/35R16. You will scrub. You will rub. You won't be able to turn properly.
Old Apr 19, 2013 | 02:00 PM
xJDMB16x's Avatar
Hey thanks man
ahron
10
Sep 9, 2007 10:25 PM
97_hatch
Apr 27, 2007 06:11 PM
ic89
11
Sep 26, 2006 05:09 PM
TurboCoop
Sep 9, 2005 11:32 AM
9KRacer
Dec 13, 2002 03:27 AM
