B16a block w/ ITR Head
Old Apr 16, 2013 | 08:13 PM
Thefamilyguy71's Avatar
Default B16a block w/ ITR Head
Hi yall! New member here and I am glad to be here. :D
I have all the materials for an ITR setup except for the block. The current block I received had all the cylinder walls cracked, so... I am thinking of going with a b16a block, or if I can find a b18c, but money is the problem so I am weighing my options, but will everything fit into the block if the rest of the stuff is ITR? In terms of my pistons they are JDM Pistons 11:1 P73.
I donno I have looked into this, but I don't feel safe on this one.
http://www.ebay.com/itm/Block-B20B-Acura-GSR-B16-B20-B18-TURBO-JDM-ITR-B18C1-B18C-EG-EK-EF-HONDA-OEM-DA-/170924078712?pt=Motors_Car_Truck_Parts_Accessories&hash=item27cbde7678&vxp=mtr
Thoughts?
Old Apr 16, 2013 | 08:29 PM
mike-y's Avatar
Default Re: B16a block w/ ITR Head
The ITR head is based on a B16A casting. They are basically the same thing, except for the ITR bits inside it, and some light porting. You'll be just fine.
Old Apr 16, 2013 | 08:34 PM
teggy!'s Avatar
get a ls block. toss the itr head ans pistons in. will be a pretty good na setup and the ls blocks are easy to find. check craigslist
Posted from Honda-tech.com App for Android
Old Apr 16, 2013 | 09:14 PM
Hm I am wonder which setup would be easier the ls or the b16a. However, I do feel like I would get better gas mpg out of the ls block, no?
Old Apr 16, 2013 | 10:33 PM
teggy!'s Avatar
b16 would be easier. but If he is already upgrading pistons why bother. all u have to do for the ls is use stepped dowels and run a oil line ...
Old Apr 16, 2013 | 10:34 PM
teggy!'s Avatar
if you. didn't notice you were the op
Old Apr 17, 2013 | 12:38 PM
Sorry Im not sure what you mean by op. Newbie here lol, but yeah I'll see what I can find, the one I posted up on ebay doesn't seem too bad, but I am seeing some b16a blocks for around the same price.
Old Apr 17, 2013 | 01:42 PM
accorse07's Avatar
Thoughts?
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/%7C%7C%7C%7C%7C-new-members-please-read-%7C%7C%7C%7C%7C-2917915/
Old Apr 17, 2013 | 03:00 PM
cruizinmax's Avatar
If your crank and rods are gsr or ls you will want to find a ls or gsr block. B16 would require b16 crank/rods.
Old Apr 17, 2013 | 04:09 PM
jdminline4's Avatar
i have an extra b16 block with crank pistons and rods. 300 plus shipping ran great. I also have your choice of cams jdm gsr or b16. I have tons of old parts laying around. Let me know if you need a obdo ecu too have 4 of them all vtec 80 to 190 for chipped ecu.
Old Apr 17, 2013 | 05:26 PM
teggy!'s Avatar
op is original poster lol
Old Apr 17, 2013 | 08:53 PM
Oh lol sorry didn't know.
I'll probably go with LS block since that is the advice I am getting, but I'll keep you guys posted.
Old Apr 20, 2013 | 04:54 PM
Alright so with the LS block, what parts would I need?
Note I have the old ITR engine fully built, but I would just be replacing the ITR block for a ls one.
I know I am going to a ls vtec conversion kit for like 200-300, but is there anything else? Or is everything else replaceable from my old ITR block?
Would I need: ??
ARP rod bolts
APR head studs
Do I need to buy new ACL bearings?
I feel like this is technically all I need to buy??
http://www.ebay.com/itm/Golden-Eagle-VTEC-FULL-Conversion-Kit-81mm-ARP-208-4303-LSVTEC-GSR-B18-B16-/261144601107?pt=Motors_Car_Truck_Parts_Accessories&hash=item3ccd6e6213&vxp=mtr
suggestions ? Am missin something?
es.roadster
Aug 18, 2010 10:21 PM
JDM_EK4_Coupe
Jun 27, 2007 11:45 AM
poormans_typer69
Sep 18, 2006 08:57 PM
austrian type-R
Aug 14, 2003 07:00 AM
PsychoSiRex
Mar 6, 2003 05:19 AM
