Honda CR-V & Element 2WD & 4WD Element & CR-V
jdm b20b erratic idle
Old Apr 16, 2013 | 06:33 PM
b20bFourDoorCivicLX's Avatar
Default jdm b20b erratic idle
has anyone with a faulty iacv had trouble using their a/c.,
my a/c wants to give out on my while driving, leads me to believe my iacv is going bad also when in neutral my idle hovers a tad over a grand and is very sticky on cold starts..takes FOREVER to settle to a grand in the morning...or after sitting for a couple hours...
jdm b20b obd1 civic
Old Apr 16, 2013 | 06:52 PM
dogbiscuit's Avatar
Default Re: jdm b20b erratic idle
there's a lot of things to check. whats the idle do while the cars running hot (the radiator fan is on) and you pull the plug to the IACV?
Old Apr 16, 2013 | 07:04 PM
the idle when hot at a redlight after a quick take off sits about 1100 then after 15 seconds shell settle back down to 1000
when a/c is put on the car will idle at 1000 some times 800 then when i drive the car will hesitate and when i come to a stop and push clutch in the idle drops low as **** then it'll be fine..same for in park
Old Apr 18, 2013 | 07:04 PM
bump anyone experience this problem before
Old Apr 19, 2013 | 04:48 AM
dogbiscuit's Avatar
have you tried what I asked? I didn't even bother helping further because you didn't even try what I asked you just tried to further explain what it's doing. Just telling us what the RPM's are is in no way helpful in trying to get your car running right.
When the car is hot (radiator fan is running) and you are parked. Pull the plug on the IACV. what does the car do then?
My suggestions. check for vacuum leaks, clean up your IACV and your throttle body.
Old Apr 19, 2013 | 05:29 PM
i went and bought a different iacv. praying it works.
my idle its stable at 1000...when cars hot and i come to a stop the idle will drop and feel like it sputters then back to normal its really annoying when in traffic ....and some times its sticky it stays above 1100 then bback to normal....
my main problem is when i put my a/c on the car is fine but when i press the gas the car sputters , LIGHTS DONT FLICKER.....IT makes it impossiable to drive....
when cars cold in the morning it takes FOREVER for the idle to settle down to 1000 like 5 minutes i cant wait some times and i just drive off and the idle will be high tell the car wants to settle down...
IACV?
Old Apr 19, 2013 | 05:30 PM
i will be putting it in tomorrow ill post an update tomorrow night
Old Apr 20, 2013 | 02:36 PM
i put in the new one, i took the old one out it was really dirty, ...and i also found out my tps sensor wasnt plugged in. so i had a dirty iacv and a disconnected tps sensor. you can imagen how my ride was...very uncomfortable .
but now the iacv has been replace , tps sensor is now connected my ride is smooth . im very happy. ;-D
Old Apr 21, 2013 | 05:43 AM
dogbiscuit's Avatar
didnt even think about that. i bet the IACV wasn't even the culprit. Also since you did replace the IACV you'll wanna bleed your coolant to make sure theres no air in the lines.
Old Apr 21, 2013 | 07:21 AM
i didnt think twice about checking, im not your best mechanic i can only pinpoint little things, i didnt notice my tps sensor was hanging off its connector, oh well the good thing is now my cars fine
dc4b20
22
Dec 3, 2012 09:54 PM
92_JDM
Engine Management and Tuning
Aug 12, 2010 03:23 PM
tylerdurden
Apr 11, 2003 05:53 PM
uneekcrx
May 17, 2002 06:45 PM
