Piston ID help!
Old Apr 16, 2013 | 06:19 AM
TGonie's Avatar
Default Piston ID help!
Ok so I had my tuner supply me with 10:1 pistons for the turbo build but there is no info on the box label or spec sheet to identify the compression ratio. I called JE and was told they are 8.5. Just by looking at these I know that is bs lol. Then I googled the part number and get a few diff listings. 9.5, 10.5 and 11
Obviously I would like to for sure know the CR of my engine before stuffing a **** ton of boost down its throat.
My setup is a B18a bored to 84mm with a b16 head. ANY HELP WOULD BE GREATLY APPREICIATED! Trying to get a awnser from JE is not going well
JE Part # is 185919 for b16a1/a2/a3 here is a pic of the actual pistons I recieved
Old Apr 16, 2013 | 10:52 AM
m_shake's Avatar
Default Re: Piston ID help!
http://www.summitracing.com/parts/jep-185919-1
Quick google search got me this
Old Apr 16, 2013 | 08:36 PM
teggy!'s Avatar
they will make different comps in different motors. google the part number and look at the chart for what block you are using
Posted from Honda-tech.com App for Android
Old Apr 16, 2013 | 08:59 PM
TGonie's Avatar
yea I dont see a comp ratio anywhere tho
[QUOTE=teggy!;48688294]they will make different comps in different motors. google the part number and look at the chart for what block you are using
http://www.buyimportperformance.com/...1_p/185919.htm
http://www.raceeng.com/p-2280-je-hon...1b16-head.aspx
http://www.cnc-motorsports.com/pisto...-0mm-bore.html
Yea ive done that but that doesnt give me a solid awnser. Isnt a ls block the same as a b20 other than bore size? So my sleeved 84mm ls block should be the same as a ls block should it not?
Check the links, diff comp ratios for the same engines... I just dont know which to believe. I doubt these are the low comp ones tho. they look like they are in the 10.5-11 range but I just want to be 100% sure before installing
Old Apr 16, 2013 | 09:32 PM
m_shake's Avatar
Compression height 1.181"
Dome volume +1.70cc
Using zealautowerks.com calculator I come up with 11.59:1, however without knowing your exact deck height and cylinder head cc, it will vary.
Old Apr 16, 2013 | 10:38 PM
teggy!'s Avatar
the b20 is the same as ls besides bore. but for some reason when I was searching I see that 84 mm is always higher comp than 81. that was with supertech pistons tho. maybe because the head isn't opened up to 84 mm
TGonie
Apr 16, 2013 08:21 AM
KamikazeDR
Jun 12, 2011 08:48 PM
cibao2ner
Apr 25, 2010 09:06 AM
Ryanthegreat1
Jun 30, 2006 09:46 PM
