Gsr swap front o2 sensor need help!
Old Apr 15, 2013 | 04:17 PM
slimjim07's Avatar
Default Gsr swap front o2 sensor need help!
I bought a 97 civic with a gsr swap in it and its throwing a code for the o2 sensor. It came wire tucked and I can't find the connector for it so I tried to wire it to the ecu with no luck. Correct me if I'm wrong but denso blue wire is signal, white is ground and the 2 blacks are heater wires. I found the ecu diagram from ffsquadtech. Any help would be greatly appreciated!
Old Apr 15, 2013 | 04:56 PM
B_Swapped93's Avatar
Default Re: Gsr swap front o2 sensor need help!
are you looking for the pinout ? it's a bit hard to understand from you'r OP obd2 to obd1 via a jumper ? or obd2
Old Apr 15, 2013 | 06:02 PM
slimjim07's Avatar
I saw a pin out on one of the threads here for a motor build. And yes I have the jumper to obd1
BlackCivicEX
29
Jan 21, 2011 07:19 AM
Ls1 FD3s
Aug 27, 2007 06:44 PM
lCHaCHeel
May 4, 2007 06:53 PM
3rdgencrx
Mar 8, 2007 04:34 PM
BoM
Aug 15, 2002 09:55 PM
