Turbo setup part out
Parting out my turbo kit and engine. Top end IS NOT for sale. Everything listed will be pulled from the car this week and ready to ship asap.
Paypal preffered, you cover payment fees and shipping.
Local pickup welcome in NY 12304. Most parts will all ship USPS Priority Mail.
PM me for specific details.
JDM B18b w/ CP 9:1 .50 over gsr pistons, Scat H beam rods w/ ARP bolts, ACL full race bearings, micro polished ls crank, 3k miles, turbo tapped oil pan, gsr oil pump $800 (CP pistons $300 Scat rods $240 LS crank $100 Oil pan $50)
Precision 1000cc injectors SOLD
Precision SC61 turbo a/r 60 hot side a/r 48, 5-Bolt outlet, turbo does show slight signs of compressor seal leaking, min shaft play, and will need a exh wheel- this ones chipped. Price lowered to compinsate for this $325
Turbo blanket, back side burned through but not seen when installed and front tie pins missing but works fine $30
Turbo k&n filter/ intake pipe $50
Tial 44mm v band waste gate w/ ss dump tube with all clamps and fittings, has one rub mark in top#' $260
Defi 2" digital racer boost gauge, blank when off blue when on $100
CC Stage-5 sprung hydro trans B-series clutch kit, 4 puck 800 miles on it $300
50mm BOV tial style w/ clamp $80
Full 2.5" steel intercooler piping and 3" cooler, flanged for v band 50mm BOV $250
Full 3" V band straight exhaust w/ blox race silancer, basically straight piped $300
Turbo 5 Bolt to 3" V-band adapter $30
Obx top mount t3/t4 manifold, modded for a sharp bend for a 44mm wastegate flange, couple cracks been welded up $200
Top mount 3" v band with flex down pipe, 3 o2 bungs $125
Baffled catch can with filter, petcock drain, ss lines with -10 black 90º fittings, needs new fittings for can $100
Custom Integra center vent guage pod, holds two 2" guages $75
Valve cover, cut for gears, powder coated metallic blue with -10 an bungs SOLD
Precision Turbo needs new seal and exh wheel has some damage on the end of the fins, min shaft play, 3" inlet and 5 bolt outlet, A/R 60 48 $325 in this condition. Rebuild kit is $75 online.
Still boosted 17psi daily in this condition.
Catch can and lines,-10an black 90* at VC, needs new fittings at can $100
Powerdex AFX Wideband O2 $200 shipped
Defi Racer 2" blue Digital boost guage, one plug epoxied in guage, works great $100
Turbo Timer $40
Custom 94+ Integra, holds two 2"guages center vent pod $75
Turbo Timer $40
Intercooler is a XS power one and has a dent in the bottom but affects just the one mount of four. Its a solid IC at 3" thick. My car made 398whp and it worked fine. I will do $700 on all of it including all clmaps, v bands, couplers.
