Honda S2000 Honda S2000
Push Start Bulb
Old Apr 15, 2013 | 03:38 AM
EJ6Civic27's Avatar
Default Push Start Bulb
Does anyone know the size/number of the bulb for the push start button? I want to replace it with a LED because the OEM bulb sucks...
Thanks.
Old Apr 15, 2013 | 12:54 PM
Boots's Avatar
Default Re: Push Start Bulb
what exactly are you talking about?
Old Apr 15, 2013 | 01:17 PM
Black S2K's Avatar
its the size of a pimple
Old Apr 17, 2013 | 03:26 AM
EJ6Civic27's Avatar
The bulb that lights up the Push Start button. I'm trying to find out what size it is, so I can replace it with an LED. Every bulb has a size...ex: the Civics gauge cluster bulbs are #74 bulbs...
Old Apr 17, 2013 | 05:20 AM
JUSTINTHECOASTI's Avatar
It's #6 in the link below (14V 0.56W)
http://www.hondaautomotiveparts.com/...atcgry5=SWITCH
Old Apr 17, 2013 | 06:15 AM
EJ6Civic27's Avatar
I did find this...but it doesn't help when trying to find an aftermarket bulb for it. That just gives me the voltage and wattage of the bulb...
Old Apr 17, 2013 | 07:55 AM
Cool. The next best thing to do would be to call them up or email them
Old Apr 17, 2013 | 08:48 AM
Driven's Avatar
it's a specialized bulb that you are not likely to find in a parts store. You have to order it from Honda.
If you're trying to replace it with a LED or bulb with different color, best bet is to remove it, measure the base and match it up.
Old May 20, 2013 | 04:42 PM
acmoc's Avatar
they don't make them
The smallest they make is led T3
and the one is smaller still
I know I have LEd's and thought of swapping the led bulb into the old housing but the led is too big to fit into the hole
Also, my car has leds in other areas and if you could get one in there it would be weaker because an led lights only the direction it faces
Old May 21, 2013 | 03:24 AM
yusenglor's Avatar
Is it normal for the Push Start bulbs to go out? I have an 04 and 06 and neither has ever lit up before...
Old May 21, 2013 | 07:00 AM
ITRbroham's Avatar
shit post warrior
My 02's push start bulb lit up but has since gone out. It's normal.
Sucks all the work just to replace it and most owners don't worry about it.
Old May 21, 2013 | 09:46 AM
afesposi's Avatar
I can't even seem to find the size. It may be a simple component led which I sell that you remove the old bulb and solder this one in its place. Email me at lightsonleds@gmail.com if you're interested. I'm an HT sponsor
Old May 23, 2013 | 02:44 PM
GhettoNinja06's Avatar
Mine was out when I bought the car. I had plans on replacing it but after finding out it's nearly impossible I just deal with it.
dickie691986
Oct 16, 2012 07:55 AM
Lucman
Nov 21, 2008 02:29 PM
Acco12dv6
Jan 26, 2007 11:31 AM
M0NEYnH0s
Apr 8, 2002 07:17 PM
