VSS WIRING PROBLEM
Ok so my speedo doesnt work so i bought a new one, but since everything is out of my way, i thought of checking the wire (blu/wht) for ground continuity. Result was possitive. Gauge connector unplugged, VSS conn. unplugged. Ecu connectors unplugged, no blown fuse. Is this normal? And the wire is connected thru a junction connector. I havent removed the pin from that connector. Does that connector give continuity to ground? Continuity beeper beeps and reads about 95 ohms. 99 civic ex
SpyderZEX
Aug 20, 2003 05:16 AM
