F23A5 engine overhoul
Hi all,
I have Accord w/h F23A5 engine and need piston ring replacement.
Can I use F23A1 piston ring into F23A5 engine?
Or can I change piston & ring piston using F23A1?
Is it work with my F23A5 ECU?
Appreciate for your kindly advice
Hari
Hari
Hi..
Thanks for your information,
But I still little bit worried since F23A1 compression is 9.3 and F23A5 is only 8.8.
If I use F23A1 piston, is it increase the compression become 9.3 also ?
And what is the effect? Is the ECU still workable with higher compression?
Thanks for your advice in advance.
Hari
Hari
these are good questions since the bore and stroke are the same on both engines. with the a1 piston,yes the c/r will increase,rings should be the same. my only worry would be valve to piston clearance. you will have to find out valve duration and travel.
DC4_MADMAN
10
Aug 23, 2006 08:52 AM
