Honda CR-V & Element 2WD & 4WD Element & CR-V
99 CRV Passenger side water leak
Old Apr 14, 2013 | 11:16 AM
dlaih's Avatar
Icon2 99 CRV Passenger side water leak
I have a 99 crv with passenger side water leak about pulling my hair out trying to find it pulled cowl sealed that all up as per several post on here made sure drains in fender and a/c were clear anyone have any other thoughts Thanks
Old Apr 14, 2013 | 11:23 AM
Infinity_Racer's Avatar
Default Re: 99 CRV Passenger side water leak
check your windshield seals. i had to remove the passenger rain gutter on the roof to find the leak on the corner of the windshield.
Old Apr 14, 2013 | 12:52 PM
ARMED's Avatar
google 99 crv passenger leak cowling.... then click on images.. kinda hard to explain but youll see how to fix it...after you search it.. i covered the square vent with a sheet of aluminum i didnt seal the vent..
Old Apr 15, 2013 | 02:57 AM
dlaih's Avatar
I have had the windshield replaced and did all the cowl repairs still have it
Old Apr 15, 2013 | 05:00 PM
Did you double check the windshield install under the rain gutter though?
Old Apr 15, 2013 | 07:46 PM
ARMED's Avatar
did you do this?
http://www.crvownersclub.com/forums/...leak-long.html
if still leaks you need to make some type of cover for the vent...that way the water wont get into the opening...but do not seal it
Old Apr 15, 2013 | 08:57 PM
crvfan's Avatar
Leave the vents on recirculate when you park it or during heavy rain and you wont have a problem, I pulled mine apart and was going to make a cover but after testing I only had an issue when the fresh air vent was open.
Old Apr 16, 2013 | 04:59 AM
dogbiscuit's Avatar
where does the water goes then?
Old Apr 16, 2013 | 03:35 PM
ARMED's Avatar
if you leave it closed, water would still get in the vents...
Evil Empire
Jun 17, 2018 07:00 AM
ARMED
Aug 17, 2015 08:11 PM
DaltonH
Dec 26, 2012 10:39 PM
///Nick
Oct 9, 2011 04:29 PM
99EXVL
Nov 1, 2009 04:06 PM
