Clutch question please help
Ok so I was driving down the street and went to shift engaged clutch pedal and it never disengaged....tried it for a minute turned off car and tried it again it worked I'm confused is that a sign of me needing my clutch replaced or something else ?? Thanks for the help
Is the fluid in your clutch reservoir low? If so, I would say something is leaking, whether it be the slave cylinder or clutch master cylinder. I'd replace whatever is leaking, bleed the clutch and you will hopefully be good to go.
I don't know because the reservoir look full maybe ill try bleeding cause it does look like a leak I think ill replace both cylinders if if all else fail Ill replace the clutch thank you well much appreciated
Nuttynutnut
May 29, 2009 06:04 PM
Ri5e
10
Sep 22, 2004 05:36 AM
DriveSideWays
Aug 27, 2004 05:06 PM
