b18b wiring swap, hondata
Old Oct 22, 2002 | 05:41 PM
boostedcvc's Avatar
Default b18b wiring swap, hondata
Okay so here it goes. I am going to be swapping the b18b motor out of a 2000 integra into my 97 civic with the d16. I know i wont have to hook up the vtec wiring but im not sure what else will have to be done. I am going to be running a hondata so i shouldn't need to do any computer wiring right? because the hondata comes with a obd2 to obd1 converter and a p28 ecu. What else will i need to do? any help will be much appreciated and relieve lots of stress!! Is there any other wiring that needs to be to the swap as a whole?
Old Oct 22, 2002 | 09:07 PM
twitchm80's Avatar
Default Re: b18b wiring swap, hondata (boostedcvc)
nope no other wiring, first off the b18b does NOT have vtec and so you won't want a p28 ecu, get a LS ecu i think its a p72(not sure though) and then wire the hondata to that, good luck
Old Oct 22, 2002 | 10:27 PM
boostedcvc's Avatar
Default Re: b18b wiring swap, hondata (twitchm80)
Engine Year Country VTEC IAB Knock Suitable ECUs Notes
B18B 96 US P74,P75,P28,P30,P72,P61 2,6,7
from the hondata website
[Modified by boostedcvc, 7:53 AM 10/23/2002]
alantam
May 1, 2007 09:29 AM
boostdc
Jun 28, 2004 01:39 AM
Sohc Driver
Apr 13, 2004 08:07 PM
teg969
Apr 5, 2004 04:55 AM
nwisehart
Apr 26, 2003 05:52 PM
