Low Offset Wheels on CRV
Found a good deal on 17x9 +25. Wondering if it would fit the CRV without issues. My CRV is lowered about 1.25 inches and I already have 215/55/17.
youll need spacers especially in the rear... our Vs stock wheel offset is +55, so you could base
your spacer's thickness from that, as for your height it wouldnt be an issue but depends on what
tire size youll be using.... may be 55series is the most height!?!?
good luck!
**theres a lot of wheels size calculator on line..
good luck!
