GSR EG Idle has mind of it's own! (Crazy Fluctuation)
Old Apr 13, 2013 | 11:27 AM
EG92DX's Avatar
Default GSR EG Idle has mind of it's own! (Crazy Fluctuation)
Finally got my GSR Swapped EG to fire up, fires up perfectly, but here's my problem. Immediately after the car turns over, engine revs it self.... all the way up to 5-8k rpm (Sometimes even 9) and fluctuates in between there. I did my vacuum lines accordingly, but i am missing the IAB check valve and I also still need to wire up my EVAP Purge Solenoid plug because I'm using a z6 harness, but still the idle shouldn't be this crazy with out those things right? Tips, suggestions , tech help greatly appreciated.
Old Apr 13, 2013 | 11:33 AM
B_Swapped93's Avatar
Default Re: GSR EG Idle has mind of it's own! (Crazy Fluctuation)
You must have a MAJOR vac leak some where the iab not wired up doesn't matter neither does the evap(as long as the line are capped) put you'r hand over the throttle body i most likly won't die listin for leaks when you do that. but first vissualy inspect that all lines are plugged in/snug
Old Apr 13, 2013 | 01:03 PM
EG92DX's Avatar
It's kind of hard to listen for the leak , remember the engine is revving in my face the whole time, could a FITV adjustment be the case, you know how you turn the flatheaded piece inside of it to adjust the idle?
Old Apr 13, 2013 | 01:17 PM
that's not the fitv give the iacv a clean just for the heck of it. is there enough slack on you'r throttle cable ?
what happens when you put you'r hand over the trottle body does it die
Old Apr 13, 2013 | 02:17 PM
vtechjunkie's Avatar
Fit could be it. It's on n the bottom of the tb. I had an issue just like yours, removed the fit valve, and viola! Gone. It's super easy, and worth a shot. Free as well.
Old Apr 13, 2013 | 06:02 PM
EG92DX's Avatar
Wait, you removed your Fitv completely?what did you do with the lines/hoses?
Car doesn't die when I put my hand over the TB and cable is fine.
Old Apr 13, 2013 | 06:12 PM
then you have a vac leak somewhere and a big one at that !. the fitv would NOT make the car idle at 5K+ rpm's are all the hoses leading to the intake manifold connected properly double check that then this:
Old Apr 13, 2013 | 06:30 PM
Louie Louie's Avatar
Just watched an eric the car guy vid on unstable idles in hondas. got the problem fixed. Many thanks to that guy.
92hxEG
Feb 21, 2017 02:31 PM
mia305sk8a
Sep 22, 2010 03:25 AM
Rob!
Mar 18, 2004 02:46 PM
autoxthis
Feb 12, 2004 09:17 PM
