Want to Buy Want to Trade/Want to Buy
B-Series IAC Valve
Old Apr 13, 2013 | 08:25 AM
skerrttt's Avatar
Default B-Series IAC Valve
Hey guys,
I'm looking for a used, but still clean and working, IAC valve. My B20 has been acting up, under very light, gradual pressure on the throttle, the RPMs will bounce from 1500-1700 RPM until the throttle is pressed in further. If I am more aggressive with the throttle, this problem does not occur. I have already replaced the TPS, put on a new fuel filter, checked and cleaned the ground wire, among other little things. I am hoping that replacing the IAC will fix this problem, but at the very least, eliminate it as a possible cause. If you think it might be something else, please let me know.
Thanks
Matt
Old Apr 13, 2013 | 10:22 AM
mgs1098's Avatar
Default Re: B-Series IAC Valve
I have one here in Va. Pm an offer.
Alan
Old Apr 14, 2013 | 12:54 AM
SlaminSohCivic's Avatar
GOT ONE $25.00 Shipped/Pp
Old Apr 14, 2013 | 06:37 AM
skerrttt's Avatar
Got one thanks
Old Apr 14, 2013 | 07:53 AM
ef2_civic's Avatar
Short or long bolt pattern?
I have one too
Old Apr 15, 2013 | 09:24 AM
JerseySiPOS's Avatar
I have an IAC for you also but there is no need. Your engine harness clips must be switched.
jofu
Honda CR-V & Element
Apr 20, 2018 06:18 AM
92cb7sk8er
Jun 21, 2011 12:34 PM
Eddog85
Jan 2, 2009 07:36 AM
suspendedHatch
May 1, 2004 11:39 PM
Excelerate
May 7, 2003 02:13 PM
