awd ek project.
Old Apr 13, 2013 | 07:47 AM
Gunni's Avatar
Default awd ek project.
the part list for my car was basicly complete drivetrain from a 99-00 crv.*
- gearbox + brackets + cables*
- starter ( you will need to grind off the starter or the block to make it fitt in - i reconmend you mock up the box and motor before you put it in and you will see right away what i mean )*
- driveshaft*
- rear differential*
- axles ( i used two right ones in my setup, reason- the rear diff in the crv is not in the middle, so the axles are differant length, but i put it in the middle in the civic an could use them with no mods at all, no need tho shorten or lengthen them )*
- trailing arms*
- lower control arms*
also used*
- integra rear shocks*
- e-brake cables from any civic with drum brakes*
- civic shuttle gas tank ( i strongly reconmend a fuelsell for this - i regret not have)*
think thats it.*
to go for front five lug ,the ITR front is the easyest way to go, do not waste time on the crv ones .
its ugly as hell but who cares*
i bought a complete drivetrain from an crv , gearbox, driveshaft ,diff ,axles ,lca´s and trailing arms ...
and shittlode off coffee :yes:
started on the trailing arms..
and started stripping it down
fitted the trailing arms...
and now "how in the ...." began ..
tried to use the crv mounting bracket for the diff but the work in changing it to fitt was stupid so i made a new one..
now the front end
took the old D out..
the crv box...
test fitted ..
this was the only mods i needed to do to but it in...
got an old b16a2 to mock it upp ..
shaft fitted in..
and hanging the diff upp was next..
next was cables ...
and now gas tank from a shuttle...
finished the front end..
hanged the shaft up..
re routed the exhaust..
painted..
assembled..
finished the floor...
and reddy to drive.
hope u like it. :sac:
Old Apr 13, 2013 | 08:08 AM
apexi_rsx's Avatar
Default Re: awd ek project.
very nice job ..... you made it like it was ment to be there... i bet that would be fun to drive with alil boost added to that torqueless b16
Old Apr 13, 2013 | 08:10 AM
civic_b18swap's Avatar
looks pretty mint good job if ya dont mind me asking how long did that take ya to do?
Old Apr 13, 2013 | 08:23 AM
Gunni's Avatar
thanx,i have a jrsc i want to fit in , i dont know if it drops in or not.
in total working days ,about a month give or take
Old Apr 13, 2013 | 08:57 AM
apexi_rsx's Avatar
im pretty sure with ur fabricating skills you could make it work or fit... anything is possible...im glad to see it done right step by step
Old Apr 13, 2013 | 08:28 PM
ozh_hawaiian's Avatar
amazing job!!! impressive one off fabrication!
Old Apr 24, 2013 | 09:00 AM
Gunni's Avatar
thanx.
Old Apr 24, 2013 | 09:34 AM
ElectronBlue00's Avatar
... holy mother of god!
This is awesome!
Old Apr 24, 2013 | 07:01 PM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
Amazing. You've done an amazing job. Congratulations.
Old Apr 24, 2013 | 07:49 PM
jbpnoman's Avatar
Have you thought about the rear diff's power handling abilities? They're basically worthless for anything more than stock power. That's the main reason I haven't started my AWD CRX yet.
Old Apr 25, 2013 | 08:01 AM
Gunni's Avatar
if it breaks it breaks..
i have abused it allot and it still holds up (so far) and im not aiming for 500 horses anyway , and if it becomes a problem then there are allot off other differentials that can hold up the abuse for longer time but they all break in the end.
the civic is lighter, and runs on smaller tires so the strain on the diff is not as much.
i have seen many different ways to modify the rear diff so it holds up and seen up to 4-500 horses so nothing should stop you...
i would start on the crx if i were you cus this is allot of fun to drive
Old Apr 25, 2013 | 09:31 AM
Schister66's Avatar
Man U FTW
You made it look too easy...nice work
Old Apr 25, 2013 | 10:20 AM
Deetz's Avatar
Crazy Honda Guy
E for effort, that is a lot of work. Not sure what country you are from, but Honda does make an AWD ek, called the Orthia. It came with the same b20 the curve did
Btw, the curve and it'd use the same front brakes
Old Apr 25, 2013 | 10:33 AM
Gunni's Avatar
iceland... i have never heard off these cars hehe
Old Apr 25, 2013 | 11:44 AM
-Gambit-'s Avatar
Very nice
Old Apr 25, 2013 | 04:14 PM
jtrent95's Avatar
You think you could post a video of it running? I'd really like to see this car in action. Great work by the way
Old Apr 25, 2013 | 06:34 PM
Gunni's Avatar
Thanx..
One in snow. Sorry for bad view..
And gravel..
http://www.rallycrosstube.com/video/3803/4wdtest2
Old Apr 30, 2013 | 02:11 PM
jtrent95's Avatar
**** man that's awesome! ^
Old Apr 30, 2013 | 03:31 PM
canadaek's Avatar
wow nice to see somebody who kept it serviable and didn't just weld the bearings into the trailing arm . maybe you could give the guy with the integra some help lol https://honda-tech.com/forums/acura-integra-6/awd-integra-gsr-build-3132031/
Old Apr 30, 2013 | 03:58 PM
RT_NEWYORK's Avatar
really cool vids and car, what was the top speed you hit on the gravel video and did you stay with the B16?
Old Apr 30, 2013 | 03:59 PM
Eddie's Avatar
Master Ninja
Always entertaining seeing this. Good work
Old Apr 30, 2013 | 04:07 PM
Texas4door's Avatar
You're a mad genius.
That is all.
Old May 1, 2013 | 06:31 AM
Gunni's Avatar
Originally Posted by canadaek
wow nice to see somebody who kept it serviable and didn't just weld the bearings into the trailing arm . maybe you could give the guy with the integra some help lol https://honda-tech.com/forums/showthread.php?t=3132031
he has sent me a few messages .
they main idea was to be able to get it fixed if i would break, and not have to modify everything again and again.
about 120-30 ish and the b16 is still in.
That is all.
hehe thanx.
Old May 1, 2013 | 06:59 AM
Elye7's Avatar
AMAZING build! are you planning on boosting that b16?
Old May 1, 2013 | 09:18 AM
ne0tas's Avatar
I just came everywhere dear lord
why did you stay with the b16 btw? you can build a b20 vtec and make gobbles more torque and power
