abs light stays on after changing axles
Old Apr 12, 2013 | 07:26 PM
raverx3m's Avatar
Default abs light stays on after changing axles
Last time i checked the abs codes it gave me codes for front abs sensors because i had non abs axles
Today i put abs axles and light is now solid. No codes and doesnt go away
There was only 2 codes for sensors prior to changing axles.
Not sure what the problem is.
Old Apr 12, 2013 | 07:40 PM
fonkernuckle's Avatar
Default Re: abs light stays on after changing axles
You have to use the procedure to reset the abs light it involves using the brake pedal etc its in the helms manual either google how to do it or use the helms manual the info is on the web
Old Apr 13, 2013 | 11:53 AM
raverx3m's Avatar
Tried doing the reset and it doesnt go through
Press brake and turn ignition on-light turns off
And instead of going back on it gives 3 spaced out blinks.
But it doesnt give me any diagnostic codes when just entering diagnostic mode it stays solid.
shortycm17
Dec 26, 2007 03:31 PM
siblue_gzer
Aug 13, 2007 12:17 PM
JasonST
May 29, 2006 08:49 AM
PROFILES2000
Oct 18, 2001 07:42 PM
ILOVEGIRLS
Sep 29, 2001 07:29 PM
