95 civic main relay keeps clicking?
Old Apr 12, 2013 | 06:27 AM
jdm 1080p's Avatar
Default 95 civic main relay keeps clicking?
so I just put a jdm h22a in my 95 civic dx and I went to start it for the first time and it pops like it want to start... but I noticed the main relay keeps clicking. ? I have a video
this video is exactly how It sounds.. this car was fine before when it had a d15b7 started everytime... also any ecu I put in always has the solid check engine light like its saying there all bad
Old Apr 12, 2013 | 08:46 AM
jdm 1080p's Avatar
Default Re: 95 civic main relay keeps clicking?
I have fuel and spark as well. someone told be to change my battery
Old Apr 12, 2013 | 12:17 PM
cvcrcr99's Avatar
Check your starter? You can jump it, too.
Old Apr 12, 2013 | 12:25 PM
mcleary333's Avatar
check battery clean terminals and tighten, make sure harness is connected tight at starter (as well as any other connections that come to mind) voltage meter very handy , if got spare relay swap it out,
Old Apr 12, 2013 | 12:34 PM
jdm 1080p's Avatar
it ceanks
Old Apr 12, 2013 | 12:36 PM
jdm 1080p's Avatar
I just bought new battery and terminals starter wire and alternator wires ill put them on and grt back to u all
Old Apr 12, 2013 | 02:26 PM
rmagnetta's Avatar
the main relay on my d16y7 was making all kinda of noise, and i was only getting 1 or 2 sparks here and there it turned out to be the main ground for the ecu on the thermostat was barely on there. not sure if h22s are set up the same. just my two cents. i just remember it would crank n crank and nothing would happen.
Old Apr 13, 2013 | 04:52 AM
jdm 1080p's Avatar
I made sure that ground was on there... I put the new battery, starter wire, and slternator wires.. I have 2 other engine grounds.. one on valve cover and on on transmission. also I went to turn on the car and now there is no check engine light. but I have fuel. I have not checked spark latley though. I guess my next thing is that... also dizzy is brand new. I checked my light bulb for the check engine light it works when I put it in my friends car its fine. anymore idea anyone thing u all want me to do
Old Apr 13, 2013 | 04:01 PM
jdm 1080p's Avatar
no spark but dizzy works in my friends car
Old Apr 13, 2013 | 04:50 PM
Lizardslap's Avatar
did the solder connections in the relay its self break try a different main relay
Old Apr 13, 2013 | 05:31 PM
DocB_Ek6_f20b's Avatar
I have a 96 dx and has the same problem went through 3 different relays battery and a starter and we just basically hard wired the relay to the power for he ignition that is connected to the relay and I haven't had the problem since if that helps
Old Apr 14, 2013 | 07:14 AM
jdm 1080p's Avatar
thats an bit sketchy lol... I havent opend the main relay is it possible to have one part of the relay bad? cuz like I said before I have fuel not spark and I can crank. also my friend said he said my ground wire is not big enough for the transmission... does anyone know if h22 has more grounds then a d15?
Nando-tech
12
Oct 7, 2014 12:16 PM
woodwardba0526
Honda Civic (2001 - 2005)
Apr 18, 2012 08:22 PM
T9U4ReBgO
Jun 19, 2010 09:07 AM
ek coupe
10
Mar 5, 2010 05:02 PM
jokr78
22
Nov 16, 2005 08:29 PM
