z6 intake manifold on y7 bogging issues
Old Apr 11, 2013 | 06:53 PM
AllmotorGSReg's Avatar
Default z6 intake manifold on y7 bogging issues
Today i did a z6 intake manifold swap on my d16y7. I used the z6 fuel rail y7 tb and y7 injectors. i used a new y7 intake manifold gasket And reused the stock y7 tb gasket because part store said it would take a week to order. The car idles fine and revs up perfect while the cars not moving in neutral, however when i drive it if i go over 1/4 throttle the car immediately bogs right out. it does this in every gear all the time. i was thinking maybe it was because i reused the stock tb gasket And maybe it was leaking but it looked fine and like i said perfect idle, it doesn't idle high like i think it would if it was the tb gasket. also was the y7 intake manifold gasket the right gasket to use? I just dude the same manifold swap last summer and i think i used the y7 gasket but can't remember. it doesn't leak any coolant. if anyone has any suggestions please let me know. i ordered a new tb gasket but that wont here till next week. all sensors map, ups, iacv are hooked up properly.
Old Apr 12, 2013 | 05:26 AM
Default Re: z6 intake manifold on y7 bogging issues
Anyone?
Old Apr 12, 2013 | 05:32 AM
JuggerNaut-CTR's Avatar
If the car is idleing fine than the bogging issue is not a vacuum leak from the t/b gasket.
Im not 100% sure but am pretty confidant you should have used the z6 I/m gasket.
Did you mix up the map and tps connector? They look the same
Old Apr 12, 2013 | 05:49 AM
B_Swapped93's Avatar
Check to see if the TPS is to spec you could have "dead spots" or it's just gone bad. mixed up with the MAP is always a possability
Old Apr 12, 2013 | 05:50 AM
Map and tps wires are correct. I've tried searching about the intake manifold basket but no luck. if it was the i.m. Gasket wouldn't it also idle rough?
Old Apr 12, 2013 | 05:53 AM
The car ran fine yesterday before i did the manifold and i used the same map and tps that was in it before same tb.
Yeah idle would be surging if there was a vac leak anywhere.
I would do as bswapped said, and check the voltage on the tps, calibrate to spec if needed.
Here same deal just an integra fourm http://forums.g2ic.com/showthread.ph...8C-*Sir-G-spec)
Old Apr 12, 2013 | 06:07 AM
I know how to test the tps and calibrate it, the issue isn't in the tps.
Old Apr 12, 2013 | 06:44 AM
The tps is dead on right where it should be when tested.
Old Apr 12, 2013 | 06:51 AM
I also noticed it revs fine in neural when its parked but if the car is moving and i hold the clutch in and rev it it bogs out.
Old Apr 12, 2013 | 07:18 AM
Btrumble84's Avatar
probably a long shot,but have you checked any ignition components, ie: wires and spark plugs..my car started bogging down when id give it gas about a month ago, changed the wires put new plugs in and it was fine after that. just something to check,ya never know.
Old Apr 12, 2013 | 07:21 AM
I noticed just now that once warmed up the car is actually idling lower then normal around 600 rpm.
Old Apr 12, 2013 | 08:04 AM
And now im noticing the car bog when i rev it in neutral when the cars not moving. important gonna replace the tb Gasket once it comes in im thinking its a vacuum issue
Old Apr 12, 2013 | 08:10 AM
HondaPartsHero's Avatar
Technical Hero
Just to confirm there is no check engine light on? And you did retain the Y7s IACV and its plugged in?
Old Apr 12, 2013 | 09:21 AM
No cel and yes d16y7 iacv and plugged in. now important not sure if its a vacuum leak i plugged the hole on the tb opening that goes to the iacv while the car was running and it imnediatly died out. id think if there was a vacuum leak the motor would have stayed running.
Now im*
Old Apr 12, 2013 | 09:35 AM
Correct so you've ruiled out vac leak essentialy. have you bled the coolant sys and is you'r timing on mech/ign
Old Apr 12, 2013 | 10:06 AM
I bled cooling system abduction i wouldn't think the timing would be off since i didn't touch distributor or t belt
Old Apr 12, 2013 | 10:08 AM
I also should note that i didn't connect the evap i capped off the charcoal canister. i wouldn't think this would cause think this would cause this issue though because i did the same thing on the same manifold swap on my 2000 dx last summer and it ran fine (car now is a 97 dx)
Old Apr 12, 2013 | 05:57 PM
Problem fixed. the fitting where the fuel hose bolts to on the fuel rail was different z6 vs y7 i had to put the fitting from the y7 rail onto the z6 rail it was starving for fuel.
Cheefer_EX
Nov 17, 2012 04:28 PM
HybridRacer69
Jul 20, 2009 12:39 AM
mr. carpenter
Apr 20, 2005 07:28 PM
ftwlucky13
Mar 21, 2005 02:43 PM
