b18b swap in ef. Won't rev past 3k rpm
Old Apr 11, 2013 | 03:04 PM
nateswim2002's Avatar
Default b18b swap in ef. Won't rev past 3k rpm
specs
b18b ob2a motor
91 civic si mpfi hatch obd0
p75-a01 obd1 ecu unchipped
obd1 jumper harness for ecu and distributor
new obd1 distributor for ckp sensor
4wire 02
no CEL codes
new fuel filter
Car sounds likes its hitting rev limiter at 3-4k rpms and it dies after 25 min of running. It also idles very rough and runs SUPER rich. I have a puddle under my exhaust from unburnt fuel. Does the same with CAT on and off.
Any ideas?
Old Apr 11, 2013 | 03:15 PM
jdmh22eg2's Avatar
Default Re: b18b swap in ef. Won't rev past 3k rpm
99% says its map sensor.
Try seeing if map and tps plugs reversed. Or if map plug is not getting good connection
Old Apr 12, 2013 | 02:50 AM
Map and tps in correct place and getting correct voltage
Old Apr 12, 2013 | 10:37 PM
HEADS OR TAILS's Avatar
wat injectors you running? did you delete the resistor box for the injectors?
Old Apr 14, 2013 | 01:42 AM
The stock injectors. I deleted my resistor box and getting a full 12 volts.
Old Apr 14, 2013 | 03:12 AM
grumblemarc's Avatar
The Grumpiest
I have never seen this problem get reported as being fixed and it always occurs after a swap. You've done something wrong of forgot to do something.
Old Apr 14, 2013 | 06:15 PM
I am replacing fuel pump tomorrow morning and if that doesn't solve my issues, I will install a different wire harness to see if it is bad wiring or grounding out.
Old Jan 31, 2014 | 06:07 PM
Fixed. Late post. Put obd 1 distributor in and fixed timing.
Migs19
Mar 29, 2016 08:53 PM
mikevar94
Mar 13, 2014 06:56 AM
bswappedej1
Oct 21, 2011 09:32 PM
Smallpox33
Aug 5, 2007 10:49 PM
tommyL
May 27, 2004 11:14 PM
