Head gasket HELP
Old Apr 11, 2013 | 04:29 AM
thekid2390's Avatar
Default Head gasket HELP
I just did a head gasket job on my car less then two weeks ago the ca has 150miles since i did it...but when i take my oil cap off i see the milk **** on my oil cap and my valve cover but when i pull my dip stick out it looks ok.... When i take the cap off the coolant system and start the car it doesnt shoot out every where... Should i do a compression test or this is normal maybe i didnt get out all the **** when i dumped the oil help please
Old Apr 11, 2013 | 06:31 AM
kyden's Avatar
Default Re: Head gasket HELP
did you have the head resurfaced?
Old Apr 11, 2013 | 08:00 PM
thekid2390's Avatar
Yes i did have it resurfaced ...my father in law said to dump all the oil and put cheap oil in it and dump the coolant and fill iit up again to see what happens this time
Old Apr 11, 2013 | 09:13 PM
aeon117's Avatar
the coolant isnt supposed to shoot out everywhere with the cap off. Only if it was pressurized, and then you remove the cap...
Also, aren't you the one with the idle problem? Looks like you got other things that could be wrong, could also lead to the idle problem...
JdmJah
16
Feb 19, 2013 06:42 PM
BigRonDawg
Jan 19, 2009 01:35 PM
djviet2000
23
Apr 29, 2008 09:36 PM
machine4321
Jul 2, 2004 11:56 AM
