Deka 630cc injectors
Old Apr 10, 2013 | 06:09 PM
bobbed750's Avatar
Default Deka 630cc injectors
Will these require a resistor box on my y8 running a p28 ecu?
https://jonbondperformance.com/index...roducts_id=421
Old Apr 10, 2013 | 06:20 PM
TheShodan's Avatar
Moderator
Default Re: Deka 630cc injectors
Those are siemen Deka Mototron 630cc injectors. You'll not need a resistor box to run those. Those are very good flowing injectors for what they are. good to use.
Old Apr 10, 2013 | 06:46 PM
bobbed750's Avatar
Thank's for the info! I just bought a z6 manifold with these injectors and an AEM fuel rail, fpr and fuel pressure gauge for 100.00.
I'd say it was a pretty good score!
Now off for some research on the resistor box needed.
Old Apr 10, 2013 | 09:10 PM
TheShodan's Avatar
Moderator
Standard resistor pack from an 88-91 Honda Accord or CRX will work. Or you can get individual resistors for the injectors.
Old Apr 10, 2013 | 11:55 PM
wantboost's Avatar
Who is Mr Robot?
The individual resistors look hideous on a wiring harness due to their size, also I've seen them heat up enough to melt through the harness sheathing and surrounding wiring
I might have one of those accord resistor boxes, it looks like a Twinkie right? I've also ft got a DSM one as well, the nicer one that is basically a big heat sink.
Old Apr 11, 2013 | 06:00 AM
Steveeghatch's Avatar
how about siemens deka 870cc injectors do they need a resistor box? are they any good?
http://www.alamomotorsports.com/FJO/injdrvr.htm
Old Apr 11, 2013 | 08:51 AM
TheShodan's Avatar
Moderator
YES. Those are the standard Siemens, and not the Mototron series, like above. When it says Low Impedence, that's the clue that they need a resistor box.
I have those in my TA Integra for over 9 years. still strong, very fast flowing. The FJO driver acts as a resistor box.
Old Apr 11, 2013 | 04:58 PM
7rrivera7's Avatar
The link to the website says they are high impedance injectors so a resistor box is NOT necessary...
Old Apr 11, 2013 | 06:38 PM
TheShodan's Avatar
Moderator
The Alamo Motorsports link uses the standard Peak/Hold injector style. Low impedance injector driver (FJO) AND Siemens deka injectors. That style is a peak/hold injector.
The Mototrons are High Impedence.
racin97
Aug 1, 2017 05:34 PM
Evansouders
Jul 30, 2013 05:50 PM
skeetahendo
Mar 15, 2008 03:44 AM
DrivinVtec
Sep 17, 2007 10:08 AM
Rod.
Apr 14, 2004 09:39 AM
