Biggest saturated injectors without wiring a resistor box?
I think the biggest is 750cc rc's. Is there any bigger ones that do not require a resistor box??? I really do not want to install a resistor box, if I have to is it easy or hard. This is for a obd1 teg with saturated injectors.
Re: Biggest saturated injectors without wiring a resistor box? (redturbocivic)
I have the saturated RC 750's, I am almost positive that they are the biggest saturated you can get. I think that you can safely get 350hp without upgraded fuel pressure. If you have aftermarket FPR and Fuel Rail, you could be safe with 400+ hp. If you plan on havin more than that, you might have to use the resistor box. I did not want to deal with the resistor box and I am happy with my HP so I say go with the RC 750's.
