low idle
Old Apr 10, 2013 | 04:16 PM
Special_K26's Avatar
Default low idle
So I clean the IACV 3 weeks ago and everything when back to normal. Then a week later I decide to buy some mobile1 and pour it in... then idle goes low. It stays like at 300.
Did I use the wrong motor oil? It's a 94 LS non-vtec with b18b1 block. Btw, I just had oil changed like a month ago right before I throw the mobile1 in. Don't know if this a problem.
Old Apr 10, 2013 | 05:05 PM
B_Swapped93's Avatar
Default Re: low idle
Did you bleed the coolant sys to get an air introduced by taking off the IACV ?. don't think the oil is the cause have you played with the idle screw ?
Old Apr 10, 2013 | 05:12 PM
goldsy's Avatar
I agree with B_Swapped93. When you pull the 2 coolant lines off the IACV you introduce air into the cooling system. Bleed the cooling system and it will hopefully clear up the problem.
Old Apr 11, 2013 | 11:02 AM
Not sure about bleeding. Do I have to do that? No I didn't mess with the screw.
NickH93
May 16, 2014 05:23 PM
mkrieger500
Mar 2, 2011 12:53 PM
vlude99
Feb 3, 2009 04:39 PM
ls19integra95
Mar 12, 2008 04:40 PM
R. Mack
Jul 14, 2005 07:29 PM
