High rev h22
Old Apr 10, 2013 | 01:10 PM
Dopejr's Avatar
Default High rev h22
I'm looking to make my h22 rev even high then 8000 rpms is it possible and if so what would you suggest to start with I know I'll have to change a few things like a tranny that can handle high revs and even the gauge clusters thoughts please
Old Apr 10, 2013 | 01:19 PM
H22AEX's Avatar
Default Re: High rev h22
from experiance i have blocked off my IACV valve and adjusted my idle control screw on my TB and it has mine steady at 1000 rpms steady and i would also suggest adjusting the Dizzy..
Old Apr 10, 2013 | 01:40 PM
Dopejr's Avatar
So how high have you been able to take your h22 rev ? I want to get to around 10,000 rpms
Old Apr 10, 2013 | 01:52 PM
Jegius's Avatar
If you don't know how, then you don't need it.. you wouldn't find more power over 8000rpm in stock engine..
Old Apr 10, 2013 | 02:09 PM
doood's Avatar
been there done that
this thread is full of fail. wtf is going on here?
Old Apr 10, 2013 | 09:14 PM
Dopejr's Avatar
I already knew I wouldn't get that out of a stock engin that's why I was asking on some options on where is the best starting points on getting a higher rev count I wasn't looking for a stupid answer just some advice on where other might have started to get their own result
Old Apr 10, 2013 | 09:23 PM
doood's Avatar
Why do you want to rev higher?
Old Apr 10, 2013 | 09:25 PM
NZXTInerTia's Avatar
You're never going to make power past 7k. There is really no point in revving it that high.
Old Apr 10, 2013 | 10:44 PM
raverx3m's Avatar
start from reading this forum
check the faq section.
nobody is gonna walk you through a whole engine build online.
you need to read. then ask questions then read more.
search honda tech through google
put "site:honda-tech.com" and add your search words after
like this
http://www.google.com/search?hl=en&safe=off&tbo=d&q=+site:honda-tech.com+integra+brake+light+on+after+replacing+calipers&sa=X&ei=h_vZUMeaH8mdiALP-4GYAw&ved=0CEIQrQIwAQ&biw=1680&bih=912
Old Apr 11, 2013 | 08:19 AM
H22AEX's Avatar
wow i really didnt see you put 8k rpms i thought you said something like 800 idle rpms.. lol .. the cut off on a h22a is like @ 6,800 rpm for JDM -USDM is @ 6,800 rpm too so your blow stuff up if your trying 8k
Old Apr 11, 2013 | 11:10 AM
ne0tas's Avatar
if you want to rev high get the jdm dohc F20b basically a destroked H22 with type s cams.
Old Apr 11, 2013 | 11:25 AM
AznBlueBoy's Avatar
Is it 2003?
You need an all out race motor with 15:1 compression and at least e85 or better with some custom cams that will make power at 10k. I rev mine to 9k. I can easily rev to 10k but it doesn't make power there so it's useless.
Old Apr 11, 2013 | 02:24 PM
DeadlockRiff's Avatar
Originally Posted by AznBlueBoy
Is it 2003?
Compression - Helps
Fuel Type - Why bother? Sourcing the fuel is a pain as it is along with the conversion.
Cams - Yes, so much yes.
Take your RPM number and throw it in the trash for the moment. Do you have any idea how much power you want to make or do you just want a high revving engine?
Old Apr 11, 2013 | 02:55 PM
jdmh22eg2's Avatar
Smhh some ppl just never get it.
Take a perfectly good engine a MULTI- billion dollar company built and think hay i csn do it better.
If they wanted the h22 to rev out that far they would have made it do that. You dont think they know were to rev EVERY engine block till it breaks?
Its called R&D and MILLIONS.
If after all that being said you still MUST rev that high, give Ross Brawn former team boss for Honda F1 a call. I am sure he can bore you to death on wha it takes to rev a motor up that high and beyond
Hope it helps.
Btw he is a super nice guy met before, tho he prob laugh at you.
Old Apr 12, 2013 | 06:10 AM
h22-eg-hatch's Avatar
I made power to 9200 in my NA h22.
I'm turbo now and make power to 9400...but I have my rev limit set to 9000 now
Just saying...
Old Apr 15, 2013 | 04:33 AM
Just saying...
His motor is 100% stock.
Big Rhag
May 7, 2015 07:50 AM
projectef
Jul 19, 2007 07:19 PM
hondaaccord94
Mar 13, 2006 11:07 AM
vtecspeed1320
Jan 30, 2006 07:40 AM
Chief Wenceslaw
Dec 5, 2005 05:24 PM
