97 del sol si engine harness
Old Apr 10, 2013 | 10:28 AM
whyS0serious's Avatar
Default 97 del sol si engine harness
Hi there HT,
So I have a 1997 Del Sol SI engine harness and I'm missing the 2nd piece of the harness where it connects to the ecu. I was wondering if there's any other 2nd piece harness that is compatible to the 97 Del sol SI I can use and isn't hard to find. Thanks
Old Apr 10, 2013 | 12:04 PM
Lizardslap's Avatar
Default Re: 97 del sol si engine harness
well I know the bay harness is identical to a honda hx
I found that out trying to find a damn alternator that fit
not sure if its different going into the car but Im guessing not it should be obd2-a
Old Apr 10, 2013 | 06:26 PM
i see thanks for your post! anybody else know?
Old Apr 13, 2013 | 12:42 PM
bump please
Old Apr 13, 2013 | 01:02 PM
Lizardslap's Avatar
just get another obd2-a harness worst that happens is its pinned for the wrong iacv and/or the o2 sensor
Old Apr 13, 2013 | 02:03 PM
94EG8's Avatar
Seagull Management
It's not, not even close.
'96 - '97 Del Sol Si will work, if it's a 5 speed model a '96 - '97 Del Sol VTEC harness will also work. '96 - '01 Integra may work. '96 - '00 Civic wont work.
Old Apr 13, 2013 | 02:57 PM
Lizardslap's Avatar
really it isnt then why cant I use a 96 del sol si alternator in my car
It is canadian so it may be different
Old Apr 13, 2013 | 03:02 PM
94EG8's Avatar
Seagull Management
Because they use the same alternator plug. All of the plugs on the harness are the same as a '96 - '00 EX civic, but the harness design is completely different. '96 - '00 Civic is one piece and goes right through the firewall to the ECU. Del Sol is 2 piece and joins at the shock tower plugs.
A legit Canadian OBD2 civic uses a 3 wire alternator plug, US is a 4 wire square plug. '96 - '00 Canadian Civics don't have an ELD that's why.
Old Apr 13, 2013 | 03:42 PM
Lizardslap's Avatar
you know I totally thought most Honda's had harnesses that unplugged on both sides
I thought it was a pretty cool feature especially when I was putting a new motor in :D
Old Apr 13, 2013 | 04:35 PM
94EG8's Avatar
Seagull Management
Some do and some don't. '92 - '95 Civics and '94 - '01 Integras also share the two piece design.
It is, although you can still pull the one piece harness with the engine, it just requires removing the battery tray and feeding the harness out through the firewall.
Old May 25, 2013 | 06:30 PM
so can anyone confirm that the 94-01 Acura Integra 2nd piece engine wire harness is compatible?
Old May 28, 2013 | 09:45 PM
bump please
Old May 29, 2013 | 11:37 PM
Bump please
Old May 30, 2013 | 03:22 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Spend the money and get the one that came with the car.
b20delslow
Jul 25, 2018 07:44 PM
stiffinEK
Nov 22, 2009 04:49 AM
eghatch4sale
16
Mar 26, 2006 06:57 PM
riptegk20
Sep 16, 2005 06:52 PM
DragII
Nov 26, 2001 10:38 AM
