b18c built check it
hi, as always i like to share my set ups with you and hear your opinions about them
b18c1 81x87.2
head pr3 polish, valves, spring and retainers all skunk2
manifold godspeed polish with 68mm thorttle body
nsx injectors 340 cc
toda spec C2 cams
honda oem gasket
block stock bore,
ctr pistons specting the compression to be between 12.0 and 12.5
arp rods and studs
planing to rev 9500 rpm
stock gsr rods
planing to tune with chrome
do u think i need to have something else? should i be able to reach 220 or +?
thanks guys i appreciated
b18c1 81x87.2
toda spec C2 cams
honda oem gasket
block stock bore,
arp rods and studs
stock gsr rods
what do YOU think?
This is a technical discussion forum. Without specific questions there is only going to be random people recommending various changes to your build for various reasons. Some good reasons, some bad reasons. And some advice is going to come from people who are uneducated on these builds.
So with that said, what do you think? And what research have you done that would support the goals you have set? Not that revving to a certain RPM should be any goal.......
what do YOU think?
and make power.... have you looked at this https://honda-tech.com/forums/all-motor-naturally-aspirated-44/10-000-rpm-2234173/
HOW are you going to rev to 9.5K on virtualy stock internals
and make power.... have you looked at this https://honda-tech.com/forums/showthread.php?t=2234173
what brought you to choose Toda C cams? what is "polishing" the head going to do?
You gotta give us something to go on because it it appears you are just throwing parts at it then that means you havent done much research to know the parts will work well. What have you researched that supports the goals you are looking for?
those CTR pistons in a GSR will be more than 12:1 compression. I specifically went with Standard B16 pistons instead of CTR to keep the compression DOWN to 12:1... CTR will be no less than 13:1 and now you're talkin race gas only. But my setup, b16 pistons .5mm oversized, titanium valvetrain and custom grind cam thats hardly as aggressive as stock ITR cams tuned with an s200 made 188whp at about 8000rpm. Revs to 9000 easily, but not making any power there. So if you actually put it together the way you say with those cams and pistons, it should make much more power than me easily, probly at a higher RPM, but have fun with that 7.50/gal race gas every fill-up.
Where is this 13:1 compression you speak of coming from? It's more like 12:1 and at most 12.5:1 with CTR pistons in a GSR. I personally ran this set-up twice now, once with P72 head and once with PR3. Both motors had measurements done and did not show anything over 12.5:1
I calculated with pr3 head and is 12.7
pump gas it is
The online compression calculators are to be used as a ballpark reference...it is in no way accurate. I only trust real world measurements of the actual head/piston/block whatever.
If i go off that zeal calculator, I am currently running 91 octane on a 13.83 CR motor? Doubtful...
, im thinking of mix 2 gal of 103 oct fuel and 4 premium fuel to ensure the quality....
