Crankshaft bolt
Old Apr 9, 2013 | 03:09 PM
VTEC+Mini's Avatar
Default Crankshaft bolt
Had an epic experience changing the timing belt. The crank bolt finally gave in but it put up a fight. I see that ARP makes a replacement. Anyone ever use one? Or have a reason not to?
Old Apr 9, 2013 | 04:13 PM
jrubenis1's Avatar
Default Re: Crankshaft bolt
If the one u took out isnt rusty and the head is fine i see no advantage to change to ARP bolts. Probably no better than OEM.
Old Apr 9, 2013 | 04:37 PM
crash!'s Avatar
^^ +2
As long as you torque it correctly, OEM will do just fine.
Old Apr 10, 2013 | 05:00 AM
VTEC+Mini's Avatar
I was told by...who knows....that the issue was the washer would develop some corrosion and it was the true culprit. The ARP washer that comes with the $30.00! bolt is made from a material they say won't corrode.
I guess this would fall under the category of "Can't hurt but likely won't help".
Old Apr 10, 2013 | 05:19 AM
kyden's Avatar
don't bother.
Old Apr 10, 2013 | 07:53 PM
quadnie's Avatar
Just anti seize the washer and threads when going back in. Always worked for me. I do like my ARP rod bolts and wheel studs tho
msmithgsr2131
14
Feb 22, 2012 04:52 AM
danielblushtein
Mar 9, 2011 05:28 PM
b20vtech
Feb 23, 2006 07:45 PM
BLUE EH3
13
Jun 6, 2005 02:04 PM
