Honda CR-V & Element 2WD & 4WD Element & CR-V
Need Help Removing This Bolt ADVICE ANYONE
Old Apr 9, 2013 | 08:44 AM
Dc2_ShowStopper's Avatar
Default Need Help Removing This Bolt ADVICE ANYONE
I been trying to remove this bolt #13. it has a different bolt size and need help taking it off. ANY ADVICE.? its driving me nuts lol
Old Apr 9, 2013 | 09:37 AM
Frozen E's Avatar
H-T White Ops
Default Re: Need Help Removing This Bolt ADVICE ANYONE
Dremel tool with a cut off disc. Chop the head off it and use a punch to push it all the way through.
Where does it hook up at anyway? The picture doesn't show that.
Old Apr 9, 2013 | 09:51 AM
it hooks up to #6
ima try that thanks for da advice
Old Apr 9, 2013 | 09:58 AM
Discosteak's Avatar
That is a stud it would be much easier to remove the nut from the bottom...........if you still need to remove the stud after all you have to do is hammer it out.
it attaches to #27 in the diagram #6 sits between the two
Old Apr 9, 2013 | 10:10 AM
NZ-DB8R's Avatar
Is it still on the car? The whole header should come off in one piece so you can attack the bolt from a better angle
Old Apr 9, 2013 | 11:10 AM
Yes, its out of the car. i tried cutting the nut on the bottom but it wont loosen up.
Old Apr 9, 2013 | 11:26 AM
Discosteak's Avatar
ITS NOT A BOLT if you have already cut the nut off just hammer it out
Old Apr 9, 2013 | 11:42 AM
I CUT THE NUT OFF. thinking it would be easier
Old Apr 9, 2013 | 12:12 PM
Discosteak's Avatar
all you have to do is hit the stud wit a hammer a few times it will pop out Ive removed more of those than i care to remember. you wont be able to spin the stud its knurled where it sits in the upper portion of the exhaust manifold
Old Apr 9, 2013 | 01:16 PM
This is what im working with
Old Apr 9, 2013 | 01:25 PM
another 1
Old Apr 9, 2013 | 01:55 PM
HELP LOL
Old Apr 9, 2013 | 02:04 PM
NZ-DB8R's Avatar
Keep cutting
Old Apr 9, 2013 | 02:52 PM
Discosteak's Avatar
cut them all off and hammer out the stud. when you want to put it back together use bolts.
Old Apr 9, 2013 | 02:53 PM
EVERYTHINGS GOOD NOW HAMMER TRICK WORKED !!!!!!!
ADeKK
Aug 7, 2010 04:10 PM
kyorishin
Apr 11, 2006 11:02 PM
cc11386
Nov 2, 2005 01:31 PM
mario82686
44
Aug 24, 2004 10:14 PM
