92 civic wont start when hot
Old Apr 9, 2013 | 06:32 AM
wcdfmt510's Avatar
Default 92 civic wont start when hot
I have a 92 civic d15b7 and when the engine is cold, it starts fine. but after driving it and the engine is (hot) up to temp and i go to start it and nothing happens. I hear the fuel pump and main relay. no cel. if doesnt do anything at all. just the interior light dim. no crank when i turn the key I dont know if it is the starter and/or ignition switch(on the steering colum) causing my problem. i have tried searching but didnt come up with much. i dont know what casuing this problem
Old Apr 9, 2013 | 06:57 AM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: 92 civic wont start when hot
coil
Old Apr 9, 2013 | 07:17 AM
wcdfmt510's Avatar
it has brand new coil and igniter
Old Apr 9, 2013 | 08:18 AM
Declectic's Avatar
Have you tried jumpin it with another car when that happens?
Old Apr 9, 2013 | 08:23 AM
Slambeard's Avatar
Did you test the starter? If so, how?
Old Apr 9, 2013 | 09:37 AM
EgNoobCx's Avatar
does it die or do you feel it stumble then die..
this happen to my del sol, when i drove and temp got to normal it would stumble then die. It ended up being the TPS on throttle. Test it and see if yours is failing.
Old Apr 9, 2013 | 10:18 AM
wcdfmt510's Avatar
no i havent tried jumping it. i have another battery i can try??
Old Apr 9, 2013 | 10:19 AM
wcdfmt510's Avatar
no i did do the starter test. just jumping it with a screwdriver rite?
Old Apr 9, 2013 | 10:22 AM
wcdfmt510's Avatar
no it never dies. its only from when its hot and i turn the car off, and when i go to start it back up it dont do anything. not even a click from the starter solenoid
Old Apr 11, 2013 | 10:28 AM
wcdfmt510's Avatar
cud it be the ignition switch harness? or the starter
Beegee208080
11
Sep 20, 2013 01:02 PM
lapilot
Apr 17, 2006 12:03 AM
sleepinlude
Apr 24, 2004 06:06 PM
Peters1983
Jul 7, 2003 09:03 AM
Cackophony
14
Jul 5, 2002 04:12 AM
