92 civic wont start when hot
I have a 92 civic d15b7 and when the engine is cold, it starts fine. but after driving it and the engine is (hot) up to temp and i go to start it and nothing happens. I hear the fuel pump and main relay. no cel. if doesnt do anything at all. just the interior light dim. no crank when i turn the key I dont know if it is the starter and/or ignition switch(on the steering colum) causing my problem. i have tried searching but didnt come up with much. i dont know what casuing this problem
Re: 92 civic wont start when hot
does it die or do you feel it stumble then die..
this happen to my del sol, when i drove and temp got to normal it would stumble then die. It ended up being the TPS on throttle. Test it and see if yours is failing.
no it never dies. its only from when its hot and i turn the car off, and when i go to start it back up it dont do anything. not even a click from the starter solenoid
Beegee208080
11
09-20-2013 01:02 PM
lapilot
04-17-2006 12:03 AM
