Transmission & Drivetrain Gearboxes, Differentials, Clutches
D-series trans problems.
Old Apr 8, 2013 | 08:40 PM
d16efsedan's Avatar
Default D-series trans problems.
k so i have a 89 si trans that im having some problems with.i was driving the car and when i went to slow down i pressed the clutch peddle in and it started lunging real bad,this lunge is only happening when i press in the clutch.it also doesnt want to stay running in neutral almost like its still in gear it will move a little and stall unless i give it gas and let the clutch out.also it makes a awful wracket when in nuetral off of the clutch but if i press the clutch peddle in it goes away.im thinking its the input shaft bearing but i could use some more info because i dont know much about transmissions.thanks guys..the trans goes into all the gears like it should and comes out of gear with no problems so i wouldnt imagine it being anything with the gearset/shift forks
Old Apr 9, 2013 | 07:25 AM
d16efsedan's Avatar
Default Re: D-series trans problems.
no one knows anything about d series trans anymore?
Old Apr 9, 2013 | 07:41 AM
kyden's Avatar
sounds right for input shaft bearing. but I suspect you also have a mechanical problem in the clutch as well though. either a clutch disc, plate, clutch fork, or cable.
Old Apr 9, 2013 | 07:53 AM
d16efsedan's Avatar
im going to go ahead and swap everything out and see what happens.
Old Apr 9, 2013 | 12:02 PM
d16efsedan's Avatar
k a little update.i decided to drive the car to my house so i can work on it.this only happens when taking off when you on the clutch after that i can shift fine with the clutch.the trans seem to not come fully out of gear in nuetral off the clutch.
Street Racer X
Sep 21, 2008 02:35 PM
BlueRex1020
Sep 24, 2006 03:56 PM
got2
Jun 20, 2006 08:49 PM
86si
Feb 3, 2006 12:04 PM
DA6Iceman
Sep 13, 2005 06:48 PM
