CIVIC INTAKE AIR TEMPERTURE SENSOR got fire??
Old Apr 8, 2013 | 07:20 PM
jonina's Avatar
Default CIVIC INTAKE AIR TEMPERTURE SENSOR got fire??
hey ht. today i swapped my intake to a short ram "96 civic" and i forgot to put in the temperture sensor back in and when i switched the key to on(II) and i saw smoke comming from underneath my hood and when i looked my temperture sensor was melting! the sensor was sitting intop of the engine harness and the tip of the sensor was melting! anyone have any idea why this would happen???
Old Apr 8, 2013 | 07:21 PM
Slambeard's Avatar
Default Re: CIVIC INTAKE AIR TEMPERTURE SENSOR got fire??
Replace IAT sensor.
Old Apr 8, 2013 | 07:24 PM
B_Swapped93's Avatar
You probably shorted something by crossing a bare wire. How is beyond me as the wires should be covered
Old Apr 8, 2013 | 07:28 PM
Slambeard's Avatar
SHOULD. Make sure you have no bare wires. That's a no-no..
Old Apr 8, 2013 | 07:58 PM
jonina's Avatar
the harness is completely stock/uncut i checked it like 3 times before i bought and put iin. :/ ill look around though. i just took the sensor off for now. thanks for the replies
Old Apr 8, 2013 | 08:01 PM
jonina's Avatar
mabe the sensor is bad? i havn't used it for about a year beacause i was running obd1. ooh and i also had an obd1 ecu "p28" when it happend. i put my stock "y7" ecu on after i took off the sensor
Old Apr 8, 2013 | 08:02 PM
apexi_rsx's Avatar
you fried something.. i hope that didint fry the iat sensor section of th ecu cuircuit board... something is shorting out to cause that or something is not right... i guess you get no problems when the sensor is unplugged?.. have you used a volt meter and turn the key on and see what kind of voltage its putting out at the plug with the key turned?
Old Apr 8, 2013 | 08:04 PM
Slambeard's Avatar
The sensor is DEFIENTLY BAD if the tip melted.. I don't think changing the ECU would affect it.
Old Apr 8, 2013 | 08:22 PM
Fnix's Avatar
Leaving a sensor unplugged shouldnt cause problems shorting and catching fire unless it touches another wire.
Old Apr 8, 2013 | 08:34 PM
jonina's Avatar
moro ill check the voltage on the plug :/ if i open my ecu would it be visible if i fried something?
and yes, everything is good without the sensor on it. and if it was a p28, it wouldnt have that sensor cuircuit board to read would it?
Old Apr 8, 2013 | 08:49 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
Did you change the ecu? That sensor is basically a resistor, if 12 volts went straight through it somehow,its going to do that, something got hooked up wrong
Old Apr 8, 2013 | 08:54 PM
apexi_rsx's Avatar
you can open the ecu and look for burns for example:
Old Apr 9, 2013 | 12:46 AM
DCRB's Avatar
p28 still looks for IAT
Old Apr 9, 2013 | 01:33 AM
HondaPartsHero's Avatar
Technical Hero
If you were replacing the harness you probably swapped the IAT for the EVAP. The IAT only sends 5V the EVAP 12V. What color are the wires going to your IAT?
Old Apr 9, 2013 | 10:58 AM
jonina's Avatar
yea, i think it was the evap. the plugs are the same :/
Old Apr 9, 2013 | 11:44 AM
Slambeard's Avatar
That is probably your problem right there.
Old Apr 9, 2013 | 12:37 PM
Well 12V's would deffenetly do that. have you checked the ecu bord.
Old Apr 9, 2013 | 08:46 PM
jonina's Avatar
i checked for burns but nothing. it looks good. guess i got lucky on this one.
Old Apr 9, 2013 | 08:47 PM
jonina's Avatar
thnks for the help you guys!
guessohw
Nov 11, 2011 02:50 PM
13g-crx
Engine Management and Tuning
20
Nov 4, 2011 12:13 PM
castle1313
Feb 4, 2010 03:56 PM
crashtest Sonny
Jun 26, 2003 01:42 PM
